strange start up and shut down noise - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-26-2013, 06:30 AM Thread Starter
i put my new exhaust on my 250 and know that i can hear it running i found two weird noises that i cant explain myself so i thought i would ask the experts. im new at diesel but not a complete air head lol. first is an exhaust noise when you first start her up and she is cold she sounds good for a little then i start to get this loud high pitch air noise but when you tap the fuel it goes away and them comes back and you have to repeat the process till she is warmed up. the second is the turbo it sounds great when she is running sool up is good everything sounds great till your turn the key off and the spool down she is loud. it is a garrett gtp38r ball bearing turbo and full mbrp 4" exhaust. here is a link to a vid of it. can you guys please tell me if everything is ok or do i have to be worried https://www.youtube.com/watch?v=XejPFkIOjxs
proxy is offline
post #2 of 9 Old 10-27-2013, 06:25 AM
delta99's Avatar
The video was hard to hear on my phone, but sounds normal to me. Your BB turbo will coast for a while after shutdown. Your load air sound is probably the exhaust back pressure valve. Most just unplug it at the pedestal to deactivate it
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #3 of 9 Old 10-27-2013, 07:39 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
the "jet" sound at idle is the EBPV valve closing to aid in warm up.
thats what it is supposed to do, dont tap the pedal. it is a valve on the turbo that closes to help create backpressure and warm the truck up.
as far as the turbo goes, its ball bearing, so it will continue to spin after the truck is off.
and whats with the intake? your just sucking a bunch of hot air having it like that.
get a real intake that draws cool air fron the fender and do the zoodad mod to get cool air from the front.
and if thats a k&n filter get it off.
do some reading on intakes to use.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #4 of 9 Old 10-27-2013, 01:00 PM Thread Starter
thanks guys the turbo was kinda making me afraid and lol yes i know about the intake this truck is in the middle of a partial resto job i bought a truck thinking all it would need was a paint job. so far front and rear axle seals both front hubs front breaks ebreak pads and im almost ready for paint lol. o and i got to figure out why the tranny is not shifting in the wright time and what the hell this kid did under the dash there is just this random 3 way toggle switch wired in and boost presser gauge in the bully dog is not reading (praying that the bully dog is not messed up) but any advise is welcome and thanks again for the help
proxy is offline
post #5 of 9 Old 10-27-2013, 02:11 PM
Quoted: 247 Post(s)
my truck had some gremlins too maintenance is the key.
ditch the bully dog and get a good chip with custom tunes, but
if its the bully dog monitor you can use it just for monitoring egt and trans temp and boost.
post #6 of 9 Old 11-02-2013, 08:11 PM Thread Starter
what is so wrong with bully dog and k&n filters?
proxy is offline
post #7 of 9 Old 11-03-2013, 06:09 AM
delta99's Avatar
The bully dog is causing your tranny shift problems. K&Ns allow more air flow, but they also happen to allow more dirt flow. You'll dust your turbo with it
delta99 is offline
post #8 of 9 Old 11-03-2013, 06:25 AM Thread Starter
OK thank you I just like an explanation better then "that **** sucks" lol thanks for the details. Is the shifting issue a comen thing with the toner and theses trucks And what toner would be recamended with the same ez of use because I'm good at repairing but when it come to programing not so much lol
proxy is offline
post #9 of 9 Old 11-03-2013, 06:32 AM
delta99's Avatar
Yeah, the shifting thing is common with Bully Dogs. You should do like Blue99 said and get a custom tune. That way your truck will be set up the way you want it...YOUR shift points, YOUR power level, YOUR environmental setting (heat, cold, altitude), etc. Better than a generic plug in
delta99 is offline
