please guys help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-25-2013, 04:56 PM Thread Starter
please guys help
so ive been dealing with this ongoing issue of what feel like a miss in my late 99 powerstroke, six speed with 147k on it. ive been replacing thing guessing and checking what could be wrong with it, i recently did the glow plugs in it along with a #8 injector and the camshaft position sensor for the second time in a year. did a buzz test on it alls good in that aspect but its got a lack of power and it acts as if it has a mean lope to it.
i look at my injector pressure while at idle it ranges from the low 500's and jumps up and down between that and the 800s
at around 1200rpms the injector pressure stutters really bad from the 1500's all the way down to the 400s and back up.
the most recent thing ive done is the valve cover gaskets today and wire harnesses. whats next guys? any input would be greatly appreciated as i am stumped.
hansonmb99 is offline
post #2 of 4 Old 10-25-2013, 05:00 PM
Rodslinger's B1TCH
any codes?
steve604 is offline
post #3 of 4 Old 10-25-2013, 05:07 PM Thread Starter
no, no codes whatsoever.
post #4 of 4 Old 10-25-2013, 06:12 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 4 Post(s)
Do you want to explain this? Does the motor miss at these pressures or is the pressure jumping possibly due to a failing HPOP?
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
Tags
7.3 , powerstroke , sevenpointthree
