winter hards starts/plugging it in - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-19-2013, 09:42 PM Thread Starter
alaskan155's Avatar
Quoted: 60 Post(s)
so i have been having a hard time starting my truck this season
got home from work last night and she would not start at all at 30* after sitting for a week, finally took a can of ether to get her going(i know bad)
i replaced the glow plugs with auto-lights when i did the cups back in apr.,
and i notice the factory relay was getting hot when i was trying to start it so i know it is getting power,
and i have rotella t in it now
i am going to order the new larger GP relay for it from guzzler's site,
my question are,
1.does synthetic oil make a huge difference?
2. anything i should look at? i added howe's diesel treatment this fillup
3. will the bigger relay help?
my other question is the engine block heater capable of being plugged in for weeks at a time? from temps in 30 at night and 60s-70s during the day? (i know it is going to get colder)
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #2 of 8 Old 10-20-2013, 12:23 PM
delta99's Avatar
I can answer some of your question. I live in CO too, and have had no start up issues with our recent cooler weather. Are you getting a SES? If not, it probably is the glow plugs. Is the glow plug indicator coming on your dash? Since you already replaced the glow plugs, I'd test your relay.
You can keep your block heater plugged in as long as you want.
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #3 of 8 Old 10-20-2013, 12:28 PM
blue99stroker's Avatar
Quoted: 246 Post(s)
autolite plugs are junk. take them out and put motorcraft plugs in.
the stock relay is junk as well.
if you still have hard starts with the new relay, i would put some 5w-40 synthetic in and you should be good from there.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #4 of 8 Old 10-20-2013, 03:05 PM Thread Starter
alaskan155's Avatar
Quoted: 60 Post(s)
i just ordered the bigger relay today will be here wendsday, was even hard to start today...
the glowplug light comes on and stays off, i have tried cycling it and waiting 2 mins and both i usually get the same result,
are the autolites that bad? thats the only thing i replace back in may when i did the injector cups as preventive maintenance, seem to start better when i bought it in march.
post #5 of 8 Old 10-20-2013, 03:31 PM
BrodieBiking's Avatar
I'm having the same problem as well. Last winter this truck would start in -15C no problem!
This morning it took me about 10 minutes to get her going, but it was only 10C outside!
Time for glow plugs? I guess i should have done them when i did inj's a couple weeks ago aha...
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #6 of 8 Old 10-20-2013, 03:51 PM
Gaius's Avatar
Quoted: 40 Post(s)
Glow plugs, relay, VC gaskets and wiring, worn injectors (biggie), or worn starting system (slow crank).
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #7 of 8 Old 11-16-2013, 11:34 PM Thread Starter
alaskan155's Avatar
Quoted: 60 Post(s)
figured i would update, my ICP sensor is going bad(leaking oil) so it is getting replaced tommarrow.
the new jumbo relay and MC glow plugs(beru) have seemed to do the trick(knock on wood), she fires up right after the light goes out now even after sitting for a while even with rotella T 15w-40.
about 4 of the autolites where deformed or not working,, and i had to start the truck up to spit the #1 autolite out(was stuck in the engine, came out complete thankfully), complete garbage and only maybe 11k highway miles on it.....
highly recommend the White rogers Relay to anyone
post #8 of 8 Old 12-04-2013, 04:41 PM
Do you have part numbers or a link for the parts you put in...???
DHR Motorsports is offline
