Mystery oil leak even more confusing. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-19-2013, 05:38 PM Thread Starter
Ok. So engine is out. Sitting on floor.
I'm still stumped on oil leak. It only leaks when engine is running. If it sitting parked, won't drip a drop, once the left over oil has drained off inspection plate.
So I know it's not oil pan (that was replaced already).
Doesn't seem to be rear main. Bell housing is covered in oil but flywheel isn't.
Fair bit of gunky oil around rear of drivers side head, all way up to plenum cover.
It looks like head gasket but I'm having hard time believing it is since oil is present above head gasket. Along bottom edge of plenum cover around bolts.
The ccv cover gaskets are shot. Took it off and they were in pieces. Could this be issue? Small amount of oil around cover but hasn't been running down, valve cover is clean.
Oil rail plugs are dry. Havnt pulled flywheel yet to check rear engine cover.
Mystery oil leak even more confusing.-image.jpg bit dark, I'll take more in daylight tomorrow.
7.3l DRW F350 4x4. stock, with exception of Airbags on rear, bilstein all around and 26k 5th wheel hitch. K&N filter for good measure.
dont try this at home kids!
Unclebobsuncle is offline
post #2 of 2 Old 10-19-2013, 05:55 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
have you verified the ebpv piston on the pedestal isnt leaking? or even the pedestal to block orings.
im giving you everything i can think of, if only someone else would chip in.
i would think you would see coolant leaking as well if it was headgasket.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
