No power when cold - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-17-2013, 08:52 PM Thread Starter
Apache Armament
greenmachine07's Avatar
No power when cold
My 99 7.3 has been having issues for the past 6 months or so (more noticeably now that its getting cold). Any time the temperature dipped below the 50s at night my truck would start just fine but when I go to take off there is absolutely no power. I can get on the road and will barely make 10 mph for the first 1/4 mile and then all of a sudden it wake up and run like normal. I'm pretty sure its not my EBPV as I've ran AE on it and no abnormal exhaust back pressure. Also, good ICP pressure/duty cycle. Glow plugs are pretty new with a white/rogers big GPR. I'm pretty suspicious that its my injectors going/gone bad. I bought the truck with 260k and it has 280 now so I'm not sure if its ever had injectors or not. Looking for a confirmation or maybe some other ideas if there are any. Thanks in advance
Early 99 SRW F-350
160cc single shots
TS performance 6 position switch with Tony's tunes.
Riffraff FRx
Riffraff HPx
Stancore GPR
2000 model turbo
Riffraff Billet wheel
DIY 6637 Intake
4 inch MBRP
Leveled on 315/75 Duratracs
greenmachine07 is offline
post #2 of 10 Old 10-21-2013, 08:43 PM
Eco Taxi's Avatar
Possibly your accelerator pedal position sensor or IPR
I had the same issue and those two helped - IPR a lot
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 10 Old 10-22-2013, 08:36 AM Thread Starter
Apache Armament
did you rebuild your IPR or get a new one?
Early 99 SRW F-350
160cc single shots
Riffraff FRx
Riffraff HPx
Stancore GPR
2000 model turbo
DIY 6637 Intake
4 inch MBRP
post #4 of 10 Old 10-22-2013, 08:47 AM
timmyboy76's Avatar
i think its your EBPV assy, doing its job...it "opens" and WHAM...you got power.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 10 Old 10-22-2013, 09:15 AM
daddyusmaximus's Avatar
Quoted: 12 Post(s)
Mine use to do that sometimes too. I just let her warm up a bit before I take off. She's cold natured, but runs great when warm.
99 F-250 Super Duty, 4X4, CCSB.
AKA: The Liberty Wagon.
daddyusmaximus is offline
post #6 of 10 Old 10-22-2013, 09:27 AM Thread Starter
Apache Armament
looked into the EBPV. I've had it unplugged for a while and theres no tone difference in my exhaust. Also, back pressure readings coming from my Autoenginuity are not increasing.
Early 99 SRW F-350
160cc single shots
Riffraff FRx
Riffraff HPx
Stancore GPR
2000 model turbo
DIY 6637 Intake
4 inch MBRP
post #7 of 10 Old 10-22-2013, 11:08 AM
Send a message via Yahoo to Commando aggie
Mine does it too and my EBPV has been gutted.
Commando aggie is offline
post #8 of 10 Old 10-22-2013, 11:53 AM
Eco Taxi's Avatar
I bought a new IPR
Kyle
Eco Taxi is offline
post #9 of 10 Old 10-23-2013, 03:31 PM
Try cleaning your EBP sensor and tube.
vanquish is offline
post #10 of 10 Old 10-23-2013, 03:40 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Did the IPR solve your problem ? I have a new IPR and it still does it . I think its the EBPV, doing its job , above 50F , it does not do it.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
