early 99 carbureted diesel? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-17-2013, 09:50 AM Thread Starter
I have an early 99 with 210k that someone who didn't know better would swear was carbureted lol. I have 6637 intake, stock straight pipe exhaust, and dp tunner but have the same problem with or without tuner. I can crank the truck and it idles smooth runs great for about two miles when I slow down to stop after that the truck lopes and idles rough then at low throttle cuts out and shakes. I can put the truck in park and sometimes it will all clear out other times I need to either rev the engine a time or two (almost like after you crank an old worn out carbureted pickup) or drive over 65mph for a couple miles. Once I get it all cleared, the truck is great until it sits several hours then we start all over. I found oil on the ICP so should have one of those the next day or so. Is this possibly my problem or where else should I be looking? Also, the truck does not smoke (other than black smoke with the tuner) and I have never had to plug it in to start.
guffey0544 is offline
post #2 of 8 Old 10-17-2013, 11:05 AM
broncomitch's Avatar
Change your oil lately?
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #3 of 8 Old 10-17-2013, 01:44 PM
JSchuricht's Avatar
The ICP sensor is a good place to start. If it's still acting up after you replace it, make sure your oil is not too old and your fuel filter isn't clogged.
JSchuricht is offline
post #4 of 8 Old 10-17-2013, 02:40 PM Thread Starter
Oil and fuel filter have less than 200 miles on them
post #5 of 8 Old 10-17-2013, 06:50 PM Thread Starter
Changed the ICP and no improvement. Forgot to mention the local dealership checked it also no codes and they said buzz test and compression are good but they "think" it is injector issues? I'm not convinced if they were bad shouldn't it run bad all the time or at least be smoking and hard to start? Advice on where to go to next?
post #6 of 8 Old 10-17-2013, 07:09 PM
CSIPSD's Avatar
Cold injectors can cause the exact issue you are explaining.
How many miles on the truck?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 8 Old 10-18-2013, 06:28 AM
Could the valve cover harness plug shaking loose cause cinda the same problem?
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #8 of 8 Old 10-18-2013, 11:20 AM Thread Starter
210k miles. I think it's a little too consistent to be uvch?
Tags
icp , idle , lope , smoke , tuner
