01' smoking in idle? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-16-2013, 12:14 PM Thread Starter
When I start my 01 7.3 cold, it takes the glow plugs around 12 seconds to warm up. After that, it emits blue/gray smoke for several minutes at quite an impressive pace from the exhaust. After that, it mostly goes away. Anyone ever deal with this?
optimusprime is offline
post #2 of 4 Old 10-16-2013, 12:33 PM
BrodieBiking's Avatar
That's a 7.3 for ya!
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #3 of 4 Old 10-16-2013, 12:50 PM
layson's Avatar
Quoted: 83 Post(s)
Burning some oil.... hows your turbo look? Sometimes if an oil seal is leaking in the turbo it can end up in the motor.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #4 of 4 Old 10-17-2013, 05:34 PM Thread Starter
I will check that. Is it easy to get apart? I have been seeing some people saying it could be a bad injector? I was having and still have very seldom an issue with the truck stalling and the wait to start and water in fuel lights coming on. It would stall and then after depressing the throttle and stepping on it again, it would start right in again. Replaced the CPS and this fixed it for the most part, except for some intermittent misses. Any ideas?
