Does new Motorcraft UVCH address the connector issue - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-13-2013, 07:46 AM Thread Starter
I am going to replace my glow plugs, gasket, and UVCH this week based on some bad tests once I get my parts in from Riff Raff and I am curious if I will have to do the fiddy cent trick or the shims? Does the newer stock from motorcraft address that issue already.
Tdog77 is offline
post #2 of 8 Old 10-15-2013, 12:54 AM
Ish.
Its better, but not foolproof.
I would use zipties, rather than the 50 cent mod.
It has failed before.
A/Ox3 is offline
post #3 of 8 Old 10-15-2013, 05:18 AM Thread Starter
Trying to visualize how a zip tie would work, not doubting you just not seeing it. I will search but do you have al link to a picture or something. Thanks
Tdog77 is offline
post #4 of 8 Old 10-20-2013, 06:01 AM Thread Starter
To answer my own question for future viewers it does. It comes with plastic post supports on the flexible clip to the point where you cannot insert the ford factory plastic clip. I sure it could still fail but I felt confident enough as it seemed quite sturdy to the point I did nothing extra with zip ties. In other words if you buy a new inventory one you cannot use the clip fix from ford so save your 15 bucks.
Tdog77 is offline
post #5 of 8 Old 11-24-2013, 11:20 AM
I actually had a Ford dealership mechanic suggest a 50 cent fix. Did it 4 years ago, and no more issue.
mikeprod92211 is offline
post #6 of 8 Old 12-05-2013, 03:27 AM
Quoted: 2 Post(s)
What's the 50 cent fix?
02 F350 CC 7.3 PS, auto, 6x6, 4.10 gears LB. AFE stage 2 intake, 4" AFE SS exh, 6.0 atf cooler, DP tuner with five stages
Eng Temp gauge, EGT guage and Trans temp gauge. J.Woods valve body ATS turbo housing. Cooling sys filter & waterless coolant. NON WORKING POS FASS fuel filter sys. Brightbox headlites. I don't care what they say "There's no replacement for displacement."
Don't believe statements about anything being better than a 7.3
GOD BLESS AMERICA!!!!
Bart_3500 is offline
post #7 of 8 Old 12-05-2013, 05:44 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
This guy figured-out how to prevent the "clip" from moving and stopping the connector from unplugging itself with a cut Quarter (X2=.50).
NoRalPh is online now
post #8 of 8 Old 12-05-2013, 10:39 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I have done the .50 mod it works great.
For you American's.... Canadian quarters are ferrous so when you drop one down by the pushrod it's easier to get out with a magnet.... I dropped a American quarter and it sucked to remove... magnet wont pick it up
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
