Flushed brake fluid and found...(with pics.) - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-12-2013, 09:56 PM Thread Starter
jordison460's Avatar
I wanted to post these two pics and get some opinions on what this might be. I have literally done 200+ brake flushes at my old job since they tried to upsell a fluid flush to every customer that walked by. I had always seen really dark fluid extracted from master cylinders and brake lines but I never saw anything like this..
About every 6 months I pull my truck in my shop and give it a quick checkup. I use a pneumatic fluid extractor and get a sample of all the fluids. I changed the brake fluid about 2 years ago and switched to the Valvoline full synthetic. The fluid itself looked fairly clean, but at the bottom of the extractor I found these black flakes that had settled to the bottom. I always clean the extractor really well so I can get an accurate idea of what going on but after seeing this I figured it might be best to get some opinions. Any help is much appreciated..
ID:	180353   Click image for larger version
ID:	180361   Click image for larger version
ID:	180385   Click image for larger version
2003 F-250 7.3 Powerstroke, 4'' straight pipe, 6637 Air Intake, DPTuner 60e-80e-120r-140ss, Coolant Bypass
*87 percent of the time statistics are made up on the spot*
jordison460 is offline
post #2 of 7 Old 10-12-2013, 10:02 PM
7.3Lifted's Avatar
Is it rust from the brake lines?
00 F350XL 7.3 RCLB ZF6 4x4
7.3Lifted is offline
post #3 of 7 Old 10-12-2013, 10:17 PM Thread Starter
It doesn't appear to be rust....but I guess I cant rule that out. The best way to describe it is that it looks like black pepper flakes. I just found it weird that the fluid color itself was still a good color and looked like "normal wear" since the last time I changed it.
Thanks for the quick reply man!
post #4 of 7 Old 10-12-2013, 10:55 PM
drivininidaho's Avatar
Quoted: 86 Post(s)
have you felt it? does it feel like rubber or hose?
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #5 of 7 Old 10-12-2013, 10:58 PM
7.3Lifted's Avatar
You could probably check to see if it is rust by putting a magnet to it.. Like drivininidaho said, I guess it could be rubber too from the hoses that are by the calipers.
post #6 of 7 Old 10-12-2013, 11:24 PM Thread Starter
Yeah I took a magnet to it first thing after I extracted it--not metal. I just added two more pics to my original post (don't know how to post pics on a reply without a url yet). Its a better pic than the first two but still not the best.
It appears to be a green metallic look now that I wiped it out of the bowl. When I touch it, the flakes instantly break apart and smear. They are not hard or rubbery feeling, but literally the instant they are touched they turn to almost a powder consistency.
Thanks again for the replys..VERY much appreciated!
post #7 of 7 Old 10-12-2013, 11:28 PM Thread Starter
JUST FOUND OUT---Meant to put this on last post, but I just noticed that most of these pieces are coming from the master cylinder. For what its worth, there is no sign of external leaking, and when the brakes are applied they respond normally and are in good shape..
