7.3 shuts off - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-07-2013, 08:06 AM Thread Starter
7.3 shuts off
Ok guys first post here and have a problem with my 02 7.3 f450 2wd. Had cps and fule pressure regulator sensor by fuel filter and the fule pressure sensor on the left front bank by valve cover all replaced . Today I was able to re-start it after it shut off and for the first time the engine light came on so I had a guy scan it with a snap on scanner but showed no code , he accidentally reset the computer and it runs fine now however engine cuts on and off sometimes over 2500 rpm's any ideas would be great help.
Dually7.3 is offline
post #2 of 13 Old 10-07-2013, 09:51 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Anytime you have a problem like that, and No Codes Found with the right scanner, I think Fuel Delivery (you get no code if you simply ran-out).
So, filter/pump/pickup/empty are where to start.
How low is the gauge now? Around 1/4?
How old is the Filter?
When it dies, turn the key off immediately and open the drain valve (yellow lever) and see what's there.
There are "screens" in the mixer (in the tank) that could be clogged maybe too.
NoRalPh is offline
post #3 of 13 Old 10-07-2013, 11:13 AM Thread Starter
Thanks for the reply so your saying screens are more likely to clog @ 1/4 tank ? like you said the tank is right at 1/4 now. The filter may have 1000 miles on it . Should be easy to check the sceens in tank since its a dump truck but not sure any tips ?
post #4 of 13 Old 10-07-2013, 12:20 PM
Quoted: 134 Post(s)
Not a clog, but rather a crack that is allowing air to get sucked instead of fuel. It's a fairly common problem to have that happen on our trucks.
Here's another recent thread -> Fuel pump sending unit
NoRalPh is offline
post #5 of 13 Old 10-09-2013, 03:37 PM Thread Starter
Ok so I cleand the screens in the mixer they were very dirty but not cloged and no visual cracks. Motor still shuts off in the higer rpm's with a full tank fuel and sometimes the cel light comes on and then goes off when I restart motor.
post #6 of 13 Old 10-09-2013, 03:44 PM
Macon's Avatar
Sounds like a weak fuel pump then. Before I jump to that conclusion, are you running tunes of any sort? If so, try going back to "stock" and seeing if that solves the problem.
Since you're messing with the fuel system anyway, might as well do the hutch mod. Welcome to guzzle's In-tank Hutch Mod Web Page
Having issues at higher RPMs is going to be fuel or oil pressure related. Fueling issues being the more probable culprit. When was the last time you changed your fuel filter? Oil?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #7 of 13 Old 10-09-2013, 03:58 PM Thread Starter
Thanks for the reply ,Fuel filter and oil filter have less than 2k. When I say it shuts off for a second or two but its rather violent on and off like switching motor on and off. Does that sound more like a pump ? The truck is bone stock except for turbo back exaust and intake so no tunes except for the ones that use to come out of the now broken radio.
post #8 of 13 Old 10-09-2013, 10:32 PM
Macon's Avatar
You said your buddy accidentally reset the computer. Was that before or after he tried pulling codes?
Starving for fuel under hard accel can feel like the engine died. Basically it's dumping fuel, and then suddenly doesn't have any. Gauges would be of great help here. Does it have issues while driving easy, or just under hard throttle?
I forget the "bucket test" for the pump, but it's something like disconnecting fuel lines and seeing how long it takes the pump to fill a 5 gallon bucket with fuel. I would suggest a jerry can so you can easily replace what you take out.
For the sake of doing easy stuff first, try a new fuel filter. It's possible that you got a bad tank of fuel and clogged that one up. I'm assuming this issue is relatively recent of course.
2002 F250 CCSB 4x4
Macon is offline
post #9 of 13 Old 10-10-2013, 04:52 AM Thread Starter
He tried pulling codes before he reset it by accident and got nothing. He though maby the trucks computer was going cause it wasn't holding the codes. Maby his snap-on scanner didn't have the correct softwere IDK. Its not always shutting down under load yesterday it was warming up for about 20 min while I loaded a machine on the trailer and when we went to drive away as I gave it a little throttle it just died.
post #10 of 13 Old 10-16-2013, 06:06 PM Thread Starter
Could my trucks symptoms be a bad IDM ?
