Over 3000 spent still hard cold start..help please.. - Ford Powerstroke Diesel Forum
post #1 of 27 Old 10-05-2013, 01:50 PM Thread Starter
so new to the diesel world I got a 7.3 2001 powerstroke, spent over 3000 in the shop this week still very hard to start when cold, if I leave it plugged in to the block heater starts and runs fine all the time...if let sit for 8 hrs it takes forever to start and than misses tell complete warm up and than runs fine... codes p1316, p1211, p0541.... I replaced all glow plugs, harnesses, valve cover gaskets, than took it in and they told me 3 injectors, intake heater, and injector modualer..3000 dollors later still same problem... any clues? the owner replaced the hpop in January so im completely in the dark now... THANKS FOR THE HELP!!
Saseaman is offline
post #2 of 27 Old 10-05-2013, 02:07 PM
superstack's Avatar
Sounds like a ether baby... or just cold blooded like mine...
Sent from my LG-LS840
superstack is offline
post #3 of 27 Old 10-05-2013, 03:28 PM Thread Starter
whats the ether? thanks
Saseaman is offline
post #4 of 27 Old 10-05-2013, 03:31 PM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
#1, there's No Such Thing as a 7.3 Either Baby, the use will eventually severely damage your engine - Never Use IT!
Next, find another shop, you're dealing with CLOWNS!!! If they throw 3K in parts (including an AIH you Never Need) and can't get it to start right, or find the reason WHY, they Don't Know What They're Doing!
You have Serious Codes, they are indicating and actual problem that an experienced shop, who is familiar with these engines, can use to find out what's wrong without pi$$ing away YOUR money on stuff you don't need...
NoRalPh is offline
post #5 of 27 Old 10-05-2013, 04:24 PM
Quoted: 818 Post(s)
Check your GP relay.
Corey@CNCFAB is offline
post #6 of 27 Old 10-05-2013, 04:28 PM
Quoted: 3 Post(s)
What he said. Replace it with the Stancor unit found here : Welcome to guzzle's Stancor GPR replacement Mod Web Page
and while you're at it, save this website:
Welcome to guzzle's Ford PSD Web Pages
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #7 of 27 Old 10-05-2013, 04:38 PM Thread Starter
Glow plug relay is good just tested it again.. Gets over 12v when switched on
Saseaman is offline
post #8 of 27 Old 10-05-2013, 04:53 PM
heisman01's Avatar
Quoted: 53 Post(s)
How cold is it where you live?
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #9 of 27 Old 10-05-2013, 04:54 PM Thread Starter
It's only like 45 dagrees at night.. When it sits over night it won't start for about 20 cycles.. Unless pluged in
Saseaman is offline
post #10 of 27 Old 10-05-2013, 05:28 PM
Quoted: 818 Post(s)
Just because it has 12V doesn't mean there is full current going through the relay. Save your money on the stancor and buy a Western snowplow relay at Napa for $13.00 They are indeed better yet.
Are you sure you checked the GP relay and not the new aih relay?
