Hissing sound - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-04-2013, 01:36 PM Thread Starter
delta99's Avatar
Hissing sound
Hi,
newbie here. I purchased a 2000 F250 used with about 240,000 miles back in July. I have added about 4,000 miles since then, and have had no problems with the engine. Yesterday and today I noticed on the way to work a hissing sound from the other side of the firewall. It wasn't so bad yesterday, but did it all the way to work today on and off. My trip is about 20 miles one way, cruising at 55-65 MPH. The noise doesn't start until the engine is warmed up into the "normal" range. Sorry, I don't have any gauges yet. The engine warms until it is just at the bottom of the normal range, and stays there. That's when the noise starts. A hissing comes on quickly, along with a slight but noticeable drop in power. The noise really sounds like a boost leak. It will last anywhere from about 10 seconds up to several minutes. Then it will stop just as quickly as it started, with a whistle sound just as it stops, sounding almost like a waste gate on a WRX or something. When it stops, the power comes back. It will then happen again after a short time. The temperature recently dropped out here, and this morning on my way to work it was 32 degrees. It happens while cruising in overdrive at constant speed, 55 mph (about 1,700 rpm) to 65 MPH (about 2,000 rpm). It does it with cruise control on and off.
I checked all the red and green lines, and all the intercooler lines. Nothing appears to be loose or disconnected. I read the sticky about the exhaust back pressure valve. The sensor was replaced by the dealership before I bought the truck. I want to think that this noise is the exhaust back pressure valve opening and closing, but I am confused. It just started when it got cold outside, making me think it is the EBPV, but why is the noise not starting until AFTER the engine is warm? And why is the noise happening on and off for the entire trip? Wouldn't the valve be closed to start until the engine is warm, then open, and stay open? Is this normal, or may I have a sensor or something that is bad? Or is it not the EBPV?
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #2 of 4 Old 10-04-2013, 01:43 PM
Sounds like your EBPV is sticking.
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #3 of 4 Old 10-05-2013, 03:11 PM
Mearntain's Avatar
That's gotta be what it is. Boost leaks wouldn't come and go, they would be a constant loss of power
2001 F250 7.3 4x4 - Reg Cab, Long Bed
AFE Stage II intake, 4" turbo back exhaust, 4 gauge Isspro pillar, PHP Hydra Chip, 35" BFG All Terrains with Fox 2.0 Shox all around, 4" lift
PSN - Rowe
Mearntain is offline
post #4 of 4 Old 10-05-2013, 03:28 PM Thread Starter
delta99's Avatar
Yeah and I checked all the boost connections and they are fine. I unplugged it at the pedestal and it didn't do it today at all. I think I'll just roll like that. Thanks for the replies
delta99 is offline
