engine compression - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-04-2013, 12:15 PM Thread Starter
wick07's Avatar
engine compression
Ok so I have been looking for a new motor (used) motor for a while now. finally found one with decent numbers which are
1- 408
2-398
3-400
4-400
5-396
6-308
7-400
8-396
How bad is number 6?
I have seen people post 5% -20% difference is this engine a ok one?
wick07 is offline
post #2 of 4 Old 10-04-2013, 12:45 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Personally, I'd keep looking. #6 inst going to get any bette, only worse. My main concern with it is what caused it to lose that much compared to all other cylinders being at or less then 1% and #6 is at almost 26%. (When averaging the other 7 cylinders)
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 4 Old 10-05-2013, 08:06 AM
timmyboy76's Avatar
according to all-data, i want to say, the "acceptable" compression difference is 35%. I know, shocked me too.
OP...does it smoke, poor acceleration, rough idle...etc. Its possible, that cylinder has a bad cup or injector not "seated" correctly or valve hang'n open...lots of variables.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 4 Old 10-10-2013, 12:36 AM
Quoted: 858 Post(s)
Feedback Score: 3 reviews
Did you do the test? Can you test again? Check to see if that injector is seated all the way down. Maybe the comp test fitting didn't get seated into the GP hole all the way and leaked by.
Corey@CNCFAB is offline
