2001 7.3 no power issue - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-03-2013, 08:05 PM Thread Starter
ok i have a 2001 f350 that has no power and i also have a 2000 f250 that runs great so to find out the problem to the 2001 i decided to swap parts from the 2000 to figure out the problem but no luck. i have changed the map, icp, ipc, turbo, ebp, cleaned and blowed through the ebp tube. checked for intake leaks exhaust leaks, fuel preassure stays above 60psi, i even swaped out computers. truck idles perfectly fine just acts like there is no boost or low on fuel preassure. no check engine light but when i disconnect the map sensor gains its power again but runs a little rough and throws a check engine light i dont get it.........
tazgli01 is offline
