2000 7.3 excessive fuel consumption - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-01-2013, 04:11 PM Thread Starter
Ok I have a 2000 F250, 7.3, 6-speed, 4x4, 223k miles. I am getting around 8 to 10 mpg at best around town, less on the highway. No oil consumption, no oil in the fuel filter, blow by is a little heavy but nothing serious but a good amount of oil from the ccv, new k&n intake, new turbo, ebps is a little gummed up but not too bad. It's a bit hard to start in the mornings(worse as it gets colder)feels like a cylinder is missing till it warms up, Injector buzz test passed with flying colors. I am fast running out of options so any ideas would be a huge help.
JE'00-250 is offline
post #2 of 4 Old 10-01-2013, 04:22 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
have you checked your fuel filter? also, you might wanna do a cylinder contribution test. do several to see if you have any inconsistencies.
cold starting issues are going to be related to your glow plug relay more than likely.
check your valve cover connectors and see if theres any burnt or worn parts. those can cause cylinder inconsistencies.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 4 Old 10-01-2013, 06:06 PM
Macon's Avatar
Check for boost leaks.
There are way too many things that can cause poor mileage to actually list. The main idea is to go over everything. Use a proper scan tool and see if anything is buggered up. AE or similar, not the parts house "we'll check your ride for free" scanner.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 4 Old 10-01-2013, 09:25 PM
Quoted: 780 Post(s)
What they said. Check your EBPS tube also.
Corey@CNCFAB is offline
