powerstroke shut off and now wont start - Ford Powerstroke Diesel Forum
post #1 of 19 Old 09-28-2013, 11:58 AM Thread Starter
Last night on my way home from the races my 03 started running rough with very little throttle response and check engine came on. This morning now it wont start. I was thinking maybe fuel filter and a buddy of mine mentioned a IPR valve/sensor? We tried scanning but no codes were found. Any other ideas?
polxc5 is offline
post #2 of 19 Old 09-28-2013, 12:40 PM
Is it low on oil? Dumb question but you'd be surprised how often it happens if not Unplug your ICP sensor and see if she fires.
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #3 of 19 Old 09-28-2013, 04:11 PM Thread Starter
the oil level is fine. could you point me towards the icp sensor. Thanks
polxc5 is offline
post #4 of 19 Old 09-28-2013, 04:46 PM
Sure thing, it's on the front upper corner of the driver side head. Looking at the engine on the right of the fuel filter you'll see a sensor mounted on the head it has 3 wires. Un plug it and if she starts you'll need a new ICP and doth forget a pigtail also
Friz186 is offline
post #5 of 19 Old 09-28-2013, 05:27 PM Thread Starter
thanks!!! tomorrows project
polxc5 is offline
post #6 of 19 Old 09-28-2013, 06:29 PM
timmyboy76's Avatar
check the uvch connections at both heads. They could also be loose under the valve covers, too...check out the "50 cent mod".
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 19 Old 09-28-2013, 06:42 PM
Quoted: 896 Post(s)
Feedback Score: 3 reviews
When it cranks does the tach move? If not check cps. If it does move, check fuses. Especially the one for the IDM. Your fuel bowl heater could've shorted it out.
Corey@CNCFAB is online now
post #8 of 19 Old 09-28-2013, 07:02 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
I'm assuming you have a 7.3L? What kind of scanner did you use? Can you read hpop? a generic scanner won't read codes on our trucks.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #9 of 19 Old 09-29-2013, 05:49 AM Thread Starter
new fuel filter and unplugged sensor friz said to and nothing. tach does not move during cranking.
polxc5 is offline
post #10 of 19 Old 09-29-2013, 06:15 AM
timmyboy76's Avatar
no tach movement, i'd look into replacing the cps
