7.3 white smoke help!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-23-2013, 05:12 PM Thread Starter
Cummins_Killer's Avatar
Okay so this all started after i changed my oil the other day, about a day after i changed the oil i ran it wide open for about 2 miles, when i got done it stunk like anti freeze, but the level didnt seem to have diffierentatied. For a couple days since then its been fine only smelling anti freeze once when i stepped on it. Today i went to start it up and it blew a tiny puff of white smoke at start up(it was a little colder then normal at 40 degrees last night). I checked the oil and it looks good, coolant is still bright green, coolant level dosent seem to have gone down noticably and i couldnt find any visible leaks. Im kinda lost now as of what to do, also never had any overheating problems. By the way its an early 99
Cummins_Killer is offline
post #2 of 4 Old 09-23-2013, 06:39 PM
Quoted: 863 Post(s)
Feedback Score: 3 reviews
If it's still the original engine it could be a tiny leak with the injector cups. The old type of "glue" they used would break down with the wrong antifreeze iirc.
Corey@CNCFAB is offline
post #3 of 4 Old 09-23-2013, 06:40 PM Thread Starter
As far as i know its the original engine, how would i go about sealing this leak?
post #4 of 4 Old 09-23-2013, 06:47 PM
Quoted: 863 Post(s)
Well, first find out if that is where it's actually coming from. Could be a head gasket to. Idk.
Any who. You have to pull the injectors, rent/buy special tool from RiffRaff diesel to remove injector cups. I believe there on their site they may have directions on how to do it.
