NEED HELP. Sudden lost of power, rough idle/loud knock - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-22-2013, 05:53 PM Thread Starter
Need some ideals on what to dig into first. This is my first diesel. My 2000 F350 SD (189,000 miles) which ran find and strong until yesterday, I was coming down the interstate when it just lost power and the check engine light came on. It also lost boost. All gauges were fine. Pulled over and looked under the hood. Truck started a louder than normal knock. After looking it over I decided to try and limp it home. Truck has almost zero power. Would only run 30-40 mph and would have to downshift on hills and slow down to 15mph. EGTs were several hundred degrees higher than normal. Boost would only hit 2-5lbs. Truck will start but idles very ruff and knocks. Check engine light is still on. Any help will be appreciated! Thanks! BEN
benward is offline
post #2 of 9 Old 11-24-2013, 01:10 PM
Check the wiring harness under the valve covers! If on is disconnected, apply a 50cent fix.
That happened to me a while back!
mikeprod92211 is offline
post #3 of 9 Old 12-05-2013, 04:24 AM
What's a 50 cent fix?
02 F350 CC 7.3 PS, auto, 6x6, 4.10 gears LB. AFE stage 2 intake, 4" AFE SS exh, 6.0 atf cooler, DP tuner with five stages
Eng Temp gauge, EGT guage and Trans temp gauge. J.Woods valve body ATS turbo housing. Cooling sys filter & waterless coolant. NON WORKING POS FASS fuel filter sys. Brightbox headlites. I don't care what they say "There's no replacement for displacement."
Don't believe statements about anything being better than a 7.3
GOD BLESS AMERICA!!!!
Bart_3500 is offline
post #4 of 9 Old 12-05-2013, 04:28 AM
Colin7.3's Avatar
You put a quarter or two underneath the plug going into the valve cover gasket. It takes the slop out and keeps it from bouncing or coming apart from vibrations
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #5 of 9 Old 12-05-2013, 04:32 AM
Is that inside the valve cover or on the outside? I was just in there so I can visualize it.
post #6 of 9 Old 12-05-2013, 04:43 AM
Colin7.3's Avatar
Outside. Its the plug going in the valve cover gasket
Colin7.3 is offline
post #7 of 9 Old 12-05-2013, 08:54 PM
lookin4myPSD's Avatar
In regards to the 50 cent fix.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #8 of 9 Old 12-06-2013, 08:23 AM
The video says that it won't work on the 02/03 7.3s I have the 02 and couldn't get anything to fit in there. So I guess I'm done and hope that never happens again. I do now have the injector harness I removed from the d.s. that was in useable shape. So I'll keep it and hopefully MANY years down the road I'll remember this if it happens again.
Thanks for the information.
post #9 of 9 Old 12-10-2013, 09:06 PM
Joe0816's Avatar
I would check to UVCH or actually the harness that plugs into the outside of the valve cover like they said, and after clicking on the video, it hits right on the head. Let us know if this is the problem!
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
