Results CCT, BUZZ etc - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-17-2013, 09:36 PM Thread Starter
OK ran some tests heres the results:
checked engine cold
Key On Engine Off
Manifold absolute pressure: 12.6 psi
Oil temp matched ambient temp +/- 2
Checked for stored codes:
DTC
p0605 NO CEL ON
Key On Engine Off Tests
p0605
Buzz Pass
Key On Engine Running Tests
P1247
P0284
CCT
p0284
Change Rotational Velocity PERDEL
CYL
3 2.3 avg
8 5.3 avg
All others read 0.0 to 0.2
Engine At Idle:
icp press 470-480 idle warm
icp duty 9.5 idle
Icp volts 0.85
HPOP TEST
WOT RUN 60MPH-90MPH 3rd Gear
ICP PSI Duty Cycle %
1865.50 15.5 Part Throttle
2762.62 20.3
2805.61 23.2
2779.59 24.1
2834.46 24.4
2832.19 24.8
2871.22 25.1
2924.40 25.3
2948.15 24.2
1528.38 16.6 Lift Off
Also noticed my Exaust Back Pressure PSI running 4-5psi higher than Manifold Absolute Pressure
Diagnosis????
ascrap2003 is offline
post #2 of 2 Old 09-17-2013, 10:24 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What your problem with the truck? Your exhaust back pressure (EBP) and turbo boost are fine if your only 4-5 difference. Typically you wanna see a EBP/turbo (manifold) psi at 2/1 when spooled up. Some times the EBP can be higher until the turbo lights! Only other real problem (besides codes) I see is your IPR duty cycle % seems low. I thought 14% was normal at idle.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
