Hesitation thru driving range. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-17-2013, 06:37 PM Thread Starter
dajain's Avatar
I am in the middle of my work week so I have not looked at the truck yet, but would love to get some points as to where to start looking.
I installed my PHP Pheonix a few weeks ago and it's been running great. A few days ago I changed the fuel filter and I started to get random a "bucking" as if the fuel is instantly being shut off. It only last long enough to buck the truck but then keeps running.
Tonight, the bucking was pretty bad on my drive home for the first 15 miles and then got better.
There are no codes stored and it happens at all rpm ranges?
Any directions I should start looking? Maybe fuel relay going bad?
Thanks ahead of time for any replies
2000 F250 PSD 4x2 SWLB
Bone stock until:
PHP 6 position switch
Gauges (pyro & Boost)
Muffler delete pipe
6637 intake
Nothing more planned except pulling my toys.
95% of Harleys are still on the road...
The other 5% made it home.
dajain is offline
post #2 of 10 Old 09-18-2013, 10:43 AM
Powerstroke Junkie
NCHornet's Avatar
My best guess would be you may have knocked one of the UVC harness connections loose on the inside of one of the valve covers. Check these connections and make sure they are good n tight with no loose or burnt conditions. Make sure the drain for the FF bowl is fully closed. If the problem is still there, pull the chip and see if this changes anything.
What are you using to scan codes? Are you sure it has the right software bundle to read our trucks since they are not OBD II compliant? Can you do any live data logging with it?
Please fill out your signature in the USER CP area and let us know what we are working on along with what you have done to it.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 10 Old 09-18-2013, 05:14 PM Thread Starter
dajain's Avatar
The Connection is one of my guesses also, but the difference between the first 15 miles and the remainder of the drive is making me think it might be an temp issue. Like the pressure requirement differences for the ICP between a hot and cold engine.
I did think of pulling the chip also, just have not done it yet.
I might have gotten a faulty CPS from Oreillys also.
The ideas keep coming, and love the input.
I just used a soft code scanner with no luck of course. I am in the middle of the work week and don't have the time until Friday but I have a friend with a diesel shop and will get the hard codes this weekend. I was surprised to find the parts store don't have the proper scanner for our truck seeing that we are in the middle of oil country with a lot of diesels.
I'll keep posted to what I find wrong, and would liove to hear other possible options also.
I'll be spending some time under the hood this weekend.
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
post #4 of 10 Old 09-18-2013, 05:18 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
The BW cps from oreilys has been known to cause those symptoms while running the windshield wipers.
i installed one on my truck last week and ran the wipers and it was fine.
so i would swap out to a different cps and see.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #5 of 10 Old 09-19-2013, 03:20 AM Thread Starter
dajain's Avatar
Yup, That is the CPS I bought. I think there is a 1 year warantee on them with oreillys, so I'll see on Friday.
With my '95 PSD, there was a spacer/shim between the block and the CPS. There is not one on this truck. Should there be?
I just cleaned the connection for the PHP chip again and I'll see if that was the issue when I drive it this morning. If the bucking happens again, I'll pull the chip and see if the issue goes away.
If not, the CPS is the next item up for business. If not that, then time to start digging into the motor on Friday
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
post #6 of 10 Old 09-19-2013, 01:16 PM Thread Starter
dajain's Avatar
This morning, I did this:
Cleaned the connections for the PHP chip and re-installed
Still bucking
Removed the chip, still bucking and no change
re-installed chip and decided to look under the hood at the ICP
ICP plug was soaked in oil
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
post #7 of 10 Old 09-19-2013, 06:53 PM Thread Starter
dajain's Avatar
Tonight, I unplugged the ICP and ran the truck. Still bucking.
Just giving an update and hoping for any input.
I'm leaning towards a faulty new CPS.
I'll put it on a computer tomorrow and we'll got from there.
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
post #8 of 10 Old 09-20-2013, 08:41 AM Thread Starter
dajain's Avatar
The verdict is in!
Oreillys CPS was bad. Went to Ford and got 2 OEM CPS's
Oreillys CPS was $31, Fords was $27.
After the CPS change, took the truck to my buddies shop and had the codes read/deleted and he did a system check with his Snap On.
I'll be ordering a ICP today and get it on the way, that sensor was reading good but a little low on the scanner, but I know that oil is bypassing and it needs to be changed before the road trip.
The girl now has a clean bill of health and ready to tow my toys.
Thanks for all the help guys!
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
post #9 of 10 Old 09-20-2013, 11:50 AM
Powerstroke Junkie
NCHornet's Avatar
Glad you got her to stop bucking, now get another CPS (FROM FORD) and carry it with you along with the tools to change it.
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #10 of 10 Old 09-20-2013, 12:05 PM Thread Starter
dajain's Avatar
LOL
One step ahead of ya. Since I was there, I bought 2.
My '95 went thru a couple of them and i don't see any design change between the 2 trucks.
Now i'm just trying to convince my wife that the new PHP chip is not what made the CPS go bad.
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
