My 01 7.3 keeps stalling/dying. Help? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-16-2013, 10:30 PM Thread Starter
Hey all. I have a new issue with my Ford. About 4 days ago, while coming down the mountain from hunting, my truck started stalling. It would basically seem to shut off, the check engine light would flash, the water in fuel light would flash and the wait to start light would come on. Still had power but the throttle wouldn't work for around 3 seconds. After letting off the throttle for that time and re engaging it, it would start running fine. It has done this about 20 times since then. The other night as I was coming off the freeway, my truck suddenly completely turned off. I lost all power steering, braking and just coasted to a stop. After putting it in park, I started it right up and drove home. Today I replaced the fuel filter hoping that would help. It shutoff once in the driveway and stalled twice coming home. I have used a water absorbent/cleaner in the tank to no avail. Im starting to get scared to think of yet another problem from this thing I recently purchased. Has anyone seen this before?
optimusprime is offline
post #2 of 5 Old 09-17-2013, 06:13 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
Anytime we have a problem like that, I think the first thing to do is to replace the CPS. They're not expensive and you should carry a spare anyway (if it didn't fix it, keep the old one as yours).
The next thing to do would be to get the truck scanned (unfortunately you need a professional scanner for this, the cheap ones the Auto Parts have aren't good enough) to find out what codes have "set" the light...
NoRalPh is offline
post #3 of 5 Old 09-17-2013, 06:19 AM Thread Starter
It has a check engine light most of the time due to the banks big hoss mod that was unstalled in the truck. I have had it scanned before several times and all the codes come back with stuff to do with the banks. Stuff like exhaust pressure fault or something similar. I would say the light is on about half the time. I have a spare cam sensor I will install and see if that does something.
post #4 of 5 Old 09-17-2013, 03:15 PM
Yep
Yep it's the crank positioning sensor down below the water pump my 2000 f350 7.3 did the same exact thing
Jaymon77 is offline
post #5 of 5 Old 09-18-2013, 09:48 AM
Powerstroke Junkie
NCHornet's Avatar
These are classic CPS issues, in the old days when the CPS failed they left you just as if someone shut the key off and tossed it out the window and there was no restarting the truck until this was replaced. This was when Ford was getting $160 for them. Now we see all sorts of intermittent problems being associated with them. As already stated, you should have a spare any way, otherwise I am not a fan of throwing parts at a problem. If this doesn't work I would pull any chip or programmed tune and return to stock.
Please fill out your signature in the User CP so we know what we are working on along with everything you have done to it. Makes our job much easier and we don't have to keep asking the same questions.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
