2000 F250 7.3 loss of power, no start, black smoke while cranking - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-16-2013, 09:02 PM Thread Starter
Hello everyone, I went to leave my home yesterday and the truck started and ran fine. I went to pull out of the driveway and the truck lost all power. It would not climb to speed with the pedal to the floor (felt similar to a plugged catalytic converter on a gasser).
I immediately turned around and drove back up the drive. Shut the truck down and restarted but loped badly at idle and kept trying to stall. The truck has never given me problems before and I am at a loss. I talked to a few mechanics and tried a few things.
The tuner has been disconnected, CPS was replaced, ICP was unplugged, Fuel filter was replaced, fuel pump is pumping, intake is clear with no restrictions, and a few other things have been tried. Now the truck will not start 90% of the time but will occasionally start but lope badly. Please help!!!
chrisaw0811 is offline
post #2 of 11 Old 09-16-2013, 09:29 PM
usteffenhagen's Avatar
Any dash lights coming on?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #3 of 11 Old 09-16-2013, 09:31 PM
ktmracer358's Avatar
If there is a cel could be uvch came disconnected. This just happened to mine there is a sticky in the tech files about it
2001f350 cclb zf6, international bellowed up-pipes, ww, diy intake, 5 inch fbd straight pipe, ky clutch, powerhungry custom tunes, glowshift pyro/boost, ffd stage 1s, frx, hpx,
ktmracer358 is offline
post #4 of 11 Old 09-17-2013, 08:19 AM Thread Starter
The check engine light came on seconds before it happened. I went to check the codes and there were none. Somehow the computer got reset, even though the battery never died and I didn't disconnect the terminals. Thanks for the replies, guys.
post #5 of 11 Old 09-17-2013, 08:24 AM
Could have been the scan tool some scan tools might not be able to access the idm to retrieve codes
post #6 of 11 Old 09-17-2013, 08:47 AM
The scanner I used didn't pick up anything either. My problem recently was my uvch also. I did the 50 cent mod to fix it. If you got the time it might be worth it to take off the valve covers and check out the connectors
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #7 of 11 Old 09-17-2013, 09:21 AM Thread Starter
I used a scanner that was compatible with this truck. It was borrowed from a buddy that works at NAPA. The presets on the radio were reset too so I know the computer was reset somehow. Is there any way to tell which side has the bad harness to save some time? Or any other possible problems?
post #8 of 11 Old 09-17-2013, 10:02 AM
Your going to have to get the cel to come back on for it to tell you weather its bank one or two if that's the problem
post #9 of 11 Old 09-17-2013, 02:06 PM Thread Starter
Okay, so I took the valve cover off on the driver side and sure enough, it was unplugged. Plugged it back in, put everything back together and it fired right up. The problem now is that when revved up it has a slight misfire which never happened before. It idles fine and has full power when opened up. But around 1500 rpm it has a slight misfire. The longer the truck ran, the less it did it. Not sure what this is now. Thanks to everyone who replied!!!!
post #10 of 11 Old 09-17-2013, 02:31 PM
Just so you know, it'll get disconnected again. U might wanna do the 50 cent mod on both harnesses. That'll be the cheapest route to prevent it from happening again
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
Tags
7.3 , fuel , icp , ipr , no start
