Injector problem, missing issue - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-15-2013, 06:12 PM Thread Starter
HunterER7's Avatar
Well to start off, I've got an 02 that is missing seriously bad when cold. Truck blows blue smoke pretty bad when cold. Once the truck warms up the miss seems to go away some. When the truck is cold(has been warmed up for at least 20 minutes) there's no power what so ever. And doesn't seem to build power til I've been driving for a while. Once driving a while there's a good bit of power gain.
Not sure what's going on here and not sure where to start first.
Any and all information can help. Thanks, earl.
HunterER7 is offline
post #2 of 6 Old 09-15-2013, 07:17 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 5 Post(s)
Well to start you need to get it scanned , buzz test , contribution test, check high pressure oil. Do you have an autoenginuity scanner or a suitable scanner?
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 6 Old 09-15-2013, 07:28 PM Thread Starter
HunterER7's Avatar
I don't have any thrown codes. Scanned the truck a couple times. I got nothing
post #4 of 6 Old 09-16-2013, 08:21 AM
Powerstroke Junkie
NCHornet's Avatar
What are you scanning it with? These trucks aren't OBDII compliant so the FREE scans won't work. Also fill out your signature so we have a clue what we are working on and what has been done to it. We need to start there before weget into what might be wrong, otherwise we are just guessing, and you don't have the time for that and neither do we.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #5 of 6 Old 09-16-2013, 01:29 PM Thread Starter
HunterER7's Avatar
Alright I'll scan it tonight after work. I did use a free scan but we have one of the big scanners here as well
post #6 of 6 Old 09-16-2013, 07:11 PM Thread Starter
HunterER7's Avatar
Welp turns out my OBDII plug is no good. Won't read the system. One problem after the next it seems
