2001 7.3 (ICP?) Issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-14-2013, 04:17 AM Thread Starter
Long time lurker and first time poster. I bought a 2001 F350 7.3 Powerstroke 4x4 Crew Cab Short Bed a couple months ago. I just recently got stationed in New Jersey, and am new to the east coast. So the truck ran fine, the only problem I had with it when I bought it was the oil pan, it is rusted in the sump, and oil is seeping through the bottom (Approx. 3-4 Drips per minute), which I figured I could fix, as I am a heavy diesel mechanic in the Air Force. I didnt know at the time that I needed to pull the entire engine to do that. Anyway, thats not my issue. About a month ago, I did an oil change, after the oil change, is when my issues started, rough idle, "hiccups" while driving at cruising speed, and finally it died on me once at a stop light, but then started right back up, and ran fine for the rest of the trip home. Thought it could be the CPS, so I replaced that, and that didn't solve the problem, so I looked next at the ICP, I unplugged it, it was filled with oil, and it smoothed out when it was unplugged, so I figured that was bad as well, so I replaced it. Once I got the new ICP in, I plugged it in, and STILL rough idle and "hiccuping" at cruising. My next venture will probably be cleaning the IPR and the EBPS and tube. I was wondering if anyone had a similar problem or could shed some light on some things I could look into. I do not have access to any sort of scanner other than my OBDII scanner from Harbor Freight. I have the ICP unplugged still, and continue to drive it and it runs pretty good, seems low on power and slightly rough idle, but nothing too bad. I've got a baby on the way and wanting to get this problem figured out. Thanks for all the help in advance.
2001 F350 XLT 7.3 Powerstroke SRW Crew Cab 4x4. "Straight Pipe" Exhaust, High Idle Mod
msimpson619 is offline
post #2 of 3 Old 09-14-2013, 06:36 AM
timmyboy76's Avatar
your on the right track, bud. I think the EBP sensor and tube need attending/replaced, along with a IPR replacement. Not a fan of "rebuilding" them. Heck, the oem lasted 13yrs, why not replace with oem new...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 3 Old 09-29-2013, 01:21 PM Thread Starter
Bump... Anyone else have any more ideas? I replaced the fuel filter today, and running diesel kleen through this tank. Still running with the ICP unplugged, and would love to have a fix.
Tags
cps , icp sensor , ipr , rough idle
