CA Glow Plug Controler - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-12-2013, 08:48 PM Thread Starter
Hello,
My name is Joe and I am new to the forum. I have a 2003 F350 7.3L. It is taking a lot of cranks to fire and I am concerned it is the glow plug controller. I have checked the resistance on the plugs and they check out. I have a CA truck and there seems to be only one relay and it is connected to the heater for the intake. The other thing is a small computer or glow plug controller on the passenger side valve cover.
From what I have been reading the CA trucks only have the control module for smog reasons and not a second relay. Can anyone clarify this for me? The second question is how can I verify that it is working.
Any help would be greatly appreciate any help.
Joe
JDMDR2003 is offline
post #2 of 5 Old 09-13-2013, 06:14 AM
timmyboy76's Avatar
determining if its working, i dont know, yet. But, the silver moduile, on the p/s vc, is the gp control module which controls both gp's...the other "relay' is the AIH one. Any non-CA truck, will have 2-aih relay looking solenoids, one for aih, other for gp's.
There is a 9-prong element, i've seen out there, hooked up to the gp module, then, fed into cab, registering 9-led lights, to signify if EACH gp is getting charged...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 09-13-2013, 08:14 AM
Powerstroke Junkie
NCHornet's Avatar
The other thing to check is the UVC harnesses on both sides. My bet is you have a problem there and not the Module. Those modules are very robust, we don't see many back here in NC, but I have spoken to tech's out West and they very seldom ever have to replace one. I know you have ohm'd them but wiggle the connector around and re ohm the plugs through the harness and see if they are still reading correctly. Last I heard that module was around $400, I would opt for one out of a junkyard or swap it with one from a friends truck before I would buy a new one.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 5 Old 09-13-2013, 08:36 AM
SuperCrutyPS's Avatar
Quoted: 317 Post(s)
Garage
If you have one of these:
Then you have a relay AND the GPM. I replaced mine a couple of years ago because it kept tripping the CEL with a code. Mine is a CA truck.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #5 of 5 Old 09-13-2013, 02:54 PM Thread Starter
Thanks guys. The help is greatly appreciated.
