99 & 2001 7.3 differences? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-12-2013, 08:10 AM Thread Starter
Quoted: 4 Post(s)
I have two 350 SD's a 99 (12/98) and 01 (9/00)
What is the difference in the base engine. Can I swap them?
The 2001 model looks to have a bigger turbo. and an air heater. Thats the only visible difference I see. The reason I want to change over is the 99 has 567,000 and a tapping lifter. The 2001 has 189.000 with some body rust in truck.
99 is MT and 01 is AT wonder all the work I'm looking at?
Anyone done a project like this before?
mcgoo422000 is offline
post #2 of 5 Old 09-12-2013, 08:22 AM
timmyboy76's Avatar
congrats on the mileage...
your "E"99, yes, has a smaller turbo, no AIH, smaller plenums where "Y" pipe connects, smaller hpop (15*)...
Should be a plug/play job, but dont quote me on that..
Your e99 "lifter" problem, is probably more of a #8, air in fuel injection problem. Doing the HUTCH mod and possibly a FRx..(riffraff diesel), would cure it.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 09-12-2013, 09:06 AM Thread Starter
Quoted: 4 Post(s)
I'm thinking the injectors are bigger also. I replaced 6 injectors and supply pump not long ago. Since the problem just started recently It could be air but I don't think so. I going to run it on a breakout box before making final decision. I started running my other 2001 350 and I like the added power as the truck goes over the hills easier than the 99 did. I justy don't want to put together a mismatched combo that is nothing but trouble. The computer and driver module is another concern I have. I attacehd pictures of both the 01 is the flatbed you can see which one looks better. The flatbed is rusted out and the cab has a bad corner and rocker panel and some dofus cleaned the paint with a brillo pad. Just trying to find out of playing doctor frankinstien will be worthwhile.
ID:	166825   Click image for larger version
post #4 of 5 Old 09-12-2013, 12:32 PM
timmyboy76's Avatar
thats a head scratcher...anyway you can post a pic of the motor from the supposed "E" 99 ? Whats thrown me off, is the "diesel" door badge and not the "powerstroke v8" badge, you'd see on the fenders, of an E99
post #5 of 5 Old 09-12-2013, 01:26 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Not all e99 had the fender badge, some did have the door badge, the "late early 99s" had the door badge. but i am confused as well, unless the blue 01 with the flat bed has replaced head lights from 99-00 the 01-04s had clear headlights. as for the white truck cant tell but it could be a e99. The engine pics will determine for sure
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
