Michigan Help - 1999 F350 Hard Lumpy Starting - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-10-2013, 12:43 PM Thread Starter
I bought a '99 F350 with 178k, 6 Spd Manual, work truck with a flatbed. The guy I bought it from had it nice and warm when I test drove it. The next morning I found truck misses quite badly and doesn't want to rev - super lumpy and low power until it warms up. I started plugging it in and it starts a lot better and levels out a lot sooner. Once warm the truck pulls hard, has normal boost patterns (I added a gauge) and idles perfect. It runs rough for a good few miles down the road when plugged in and longer when not plugged in.
I did check the glow plug relay and it looks to be working correctly. I am located in South Lyon MI and am looking for someone that can troubleshoot the problem that knows these trucks.
greasolution is offline
post #2 of 13 Old 09-10-2013, 02:16 PM Thread Starter
I just ran a couple tests based on some threads I found. The resistance test for the glow plugs showed most at .8 a couple at 1.2 and the drivers front at infinite. Testing the relay came out at 11.85V staying on for 50 seconds in 90 degree heat here today.
post #3 of 13 Old 09-10-2013, 05:07 PM
Quoted: 722 Post(s)
Relay is OK, but you have a few bad glow plugs.
Corey@CNCFAB is online now
post #4 of 13 Old 09-10-2013, 09:45 PM Thread Starter
If the truck runs rough for an extended period of time (3-5 miles) even after being plugged in in the summer, does this point more to injectors than glow plugs? Meaning some of the glow plugs need replacing but most likey the problem will still be there after they are replaced.
post #5 of 13 Old 09-11-2013, 06:00 AM
Quoted: 722 Post(s)
Have you been able to do a buzz test with a good diagnostic computer?
There are lots of things to check. IPR ICP EBPV EBPS. Bad turbo?
post #6 of 13 Old 09-11-2013, 06:15 AM
Quoted: 722 Post(s)
If your on a budget you can get this.
BAFX Bluetooth obd adapter and TorquePro app on Verizon store and read all your vitals live and scan/clear codes for $30-40 total. Its definitely not AutoEnginuity, but its very nice.
post #7 of 13 Old 09-11-2013, 08:37 AM Thread Starter
I'm looking at this one:
http://www.amazon.com/BAFX-Products-PIC18F2480-diagnostics-compatible/dp/B005NLQAHS
What parameters will I be able to monitor that will be useful on the 7.3L?
post #8 of 13 Old 09-11-2013, 09:14 AM
Quoted: 722 Post(s)
Everything that your PCM sees. 219 different parameters, sensors, etc. You just can't do all the tests like AE.
post #9 of 13 Old 09-11-2013, 10:01 AM Thread Starter
I will order one of these. For this issue what should I take a look at?
post #10 of 13 Old 09-11-2013, 11:16 AM
Quoted: 722 Post(s)
It would be a good idea for you to read through the stickies in the '99-'03 forum. Lots of good troubleshooting and maintenance guides.
