97 Turbo Removal - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-04-2008, 12:10 PM Thread Starter
97 Turbo Removal
I am trying to get my turbo off but I can't get a wrench on the bottom two nuts of the exhaust transition piece on the turbo. I got everything else off but these nuts look impossible. What’s the trick?
davis3510 is offline
post #2 of 5 Old 06-04-2008, 01:03 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
See if this helps any. I have had mine off a couple times, and this is how I did it.
It is tricky. http://www.powerstroke.org/forum/7-3...tion-tips.html
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360° thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #3 of 5 Old 06-04-2008, 04:53 PM Thread Starter
Thanks Derrick!! That write up is just what I was looking for.
Chris
post #4 of 5 Old 06-04-2008, 05:03 PM
15mm crowsfoot. PB Blaster or WD40.
Diesel Monkey is offline
post #5 of 5 Old 06-05-2008, 02:08 PM Thread Starter
Ok, the swivel socket worked. I got the flange off. I have also got three of the four pedestal bolts out or loose. I can not even get my finger on driver's side rear bolt much less a wrench. How did you guys get to this thing? Is the exhaust intake "Y" suppose to drop down once you get the flange to the turbo broke loose and the clamps to the exhaust manifolds off. The way I see it the only way to get to the last bolt is for the exhaust "Y" to drop down. However I can't get it to move enough for the bottom studs to clear the turbo flange. It as dropped about a 1/16” but no more.
I have been repairing my cars for over 20 years and I have never done anything as tough as this turbo removal. Someone please tell me it goes back together easier then it came apart.
Chris
