Hidden Oil Leak - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-05-2013, 11:13 AM Thread Starter
Hidden Oil Leak
I have an 02,F-450 6 speed, with 80,000 miles. I'm the original owner.
It has started to leak motor oil at the back of the motor. It leaks like the rear main, but I dont think it is. It only does it when I have a load behind it, and its been pulling for a while. When it starts to leak it really puts it down ! Unhooked the trailer and put it in the shop. Couldent find a leak wile it was on the racks. Took a load of horses about 100 miles , and by the time I got unloaded it was rolling. Looked like a blood trail from a lung shot Elk.
Bobtail into town 30 miles or so, and not a drop will be leaked. Got me scratching my head.
Any Ideas as to what would leak when it gets warmed up good ?
leemar28 is offline
post #2 of 6 Old 09-05-2013, 01:37 PM
Powerstroke Junkie
NCHornet's Avatar
Most common areas would be the O rings and the ends of the HPO lines at each head. But why it is doing it only when a load is behind it is what doesn't make sense to me. Do you have gauges? What kind of boost are you pulling? Look at the pedestal O Rings where the turbo mounts as well, oil should leave a trail behind. Auto Parts stores sell a UV dye that you put in the oil and then use a black light and the trail will glow like magic!!!
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 6 Old 09-05-2013, 01:47 PM
JSchuricht's Avatar
There are a few common spots on top of the motor that will leak into the valley and run down a weep hole to the rear. Check around the turbo, there are two orings between the turbo and the pedestal, another two between the pedestal and the block. Also check the HPOP toward the front of the motor in the valley. It can leak where it mounts to the motor, around it's plug or at either of the two hoses coming out of it.
JSchuricht is offline
post #4 of 6 Old 09-05-2013, 05:26 PM Thread Starter
NC, Not sure what kind of gauges you are refering to. Every thing is stock. Not sure what you mean by 'Boost". Only leaking under load has all of us puzzled. I will try to locate that dye ! Sounds like that could sure help locate the problem.
J, I looked and there is a bit of oil in the valley. Not much but some. I will allso look for a better mechanic !!! Thanks for the tips !!!
leemar28 is offline
post #5 of 6 Old 09-05-2013, 07:53 PM
lookin4myPSD's Avatar
It could possibly be the HPOP Mounting gasket. I've seen a few of those leak. Everybody freaks out and thinks its the RMS, but it's very misleading. I did the same thing and was about to pull my engine when somebody talked sense into me.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #6 of 6 Old 09-06-2013, 06:20 AM
russtwentyfour's Avatar
I would say an high pressure oil line either at the hpop or head. Increasing load equals increased throttle equals increased hpop pressures. Just my guess
If it where mine I would clean valley and back of motor let dry completely hook a load up and follow the oil.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
