oil leak- front of motor - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-01-2013, 12:25 PM Thread Starter
09pstrokeUSMC's Avatar
hey i was wondering if anyone could tell me really quick what they think the oil could be coming from.
i have oil running down the front of my block by the pulleys and it drips onto radiator hose and all other components under front of block..... i go up top and dont see anything, could it be leaking around bottom of HPOP or something else.
i have a little oil in valley of motor too, which i believe to be EBPV . its been giving me hell for a while. going to just delete it. but i am also running into running rough and poor starts. could all of this indicate bad HPOP or bad HPOP pressure? how do i test HPOP pressure?
09pstrokeUSMC is offline
post #2 of 2 Old 09-01-2013, 09:14 PM
russtwentyfour's Avatar
Low pressure oil pump which is right behind balancer on crankshaft.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
