poor running 7.3 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-01-2013, 07:40 AM Thread Starter
poor running 7.3
So last week as I'm getting up to freeway speeds the truck starts acting like it is got a bad mis. I have the local ford dealer run a diagnostic test and they say the #2 injector is dead, the #3 injector is weak and a possible injector module controller being bad.
So I open both valve covers and do the 25cent fix. Didn't fix it. I replace the #2 injector, didn't fix it. Could the weak injector be causing the problem to continue or is it the module.
workin it is offline
post #2 of 4 Old 09-01-2013, 07:57 AM
jesilvas's Avatar
Quoted: 3 Post(s)
If your under valve cover harnesses and pigtails connectors are good, and oil is fresh, I would change camshaft position sensor first, then possibly look at the InjectorDriverModule.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 4 Old 09-01-2013, 08:09 AM Thread Starter
poor running 7.3
Thanks, should I change the #3 injector or is this a case of something else is making the injector weak.
post #4 of 4 Old 09-01-2013, 08:40 AM
jesilvas's Avatar
Quoted: 3 Post(s)
I don't think it's the injectors. I'd run a buzz test and cylinder contribution test anyway.
4R100, 2wd
330,000 + miles
jesilvas is offline
