clutch fan - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-29-2013, 04:37 PM Thread Starter
alaskan155's Avatar
Quoted: 65 Post(s)
clutch fan
i was wondering, it been in the 80/90s lately, and i noticed my clutch fan like to kick in alot going down the highway/in town, is this normal for the 7.3? seem to engage more than the gas motors i had before it, so does the 7.3 run hotter/set to engage earlier?
i do alot of running at 75-80 if that matters, there is no back and forth play in the clutch fan/ resistance when off, thermostat is a new ford oem with rotella elc(none of the temps are high according to my torque app)
seem to kick in alot running both in town and on the highway, and i know these are mechanical clutches(no electrics)so i don't think max a/c would cause it,
and all this is running empty
thank-you
usually when my clutch fans go bad there was either play in them or they didn't kick in anymore lol, so this one has me for a loop on whether its good or bad.
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #2 of 11 Old 08-31-2013, 06:25 AM
Quoted: 169 Post(s)
Feedback Score: 3 reviews
First, the cooling system in these trucks is so over-engineered and that clutch is rarely noticed. At 75-80 you don't need a fan at all.
The test is really, are you ever seeing high temps?
You could also try feeling the resistance to turning when cold (there will be considerable resistance) and compare it to, as hot as you think it gets. Not sure how useful that is, it's gonna be hard to judge it's actually hot enough for the clutch to start locking.
NoRalPh is offline
post #3 of 11 Old 08-31-2013, 07:10 PM Thread Starter
alaskan155's Avatar
Quoted: 65 Post(s)
i can tell its locking at 75mph lol, you can here it kick in when i put my foot down to pass, the fan isn't exactly the quietest at 2500rpm or so lol, usually unlocks a few miles down the road, then does it again on and off threw my drive home(about 50 miles on the highway)
guess ill run my scanner program and see what temps the engine is reaching in the day, just more surprising since i don't have trailer on it, it shouldn't be getting that hot i would think....
also i just replace the fan clutch on my 88 bronco, and the resistance is about the same when the engine is off and cold on both vehicles, not sure when the engine is hot though, was quite today running around town in the mid- low 80s, so i think it just engages more when its 90+ outside. but i have ran other gas trucks in 90+ degree weather(oklahoma for example/south texas in august) both fords and have never engaged as much as this diesel lol.
post #4 of 11 Old 09-01-2013, 05:14 AM
Quoted: 169 Post(s)
I don't think I've ever noticed noise form my clutch engaging (not like heavy trucks where you can't miss it!), maybe I'm not paying enough attention
As I said, I'm not sure when you could know the temp was enough to engage it and try to compare the resistance. I would Not think at 75mph the fan could actually be needed (how much more airflow could it be adding?). There are posts I've read, from people in hot regions of the country, who talk about removing their fans all together and not having Any Problems, even in Traffic!!!
A note on the scanner, I know the AE I use does not accurately give coolant temp reading, and I think the gauge in your cluster is actually giving you Oil temp readings (in an Auto truck). So, if your scanner gives you suspicious temp readings you might not believe what you're getting.
NoRalPh is offline
post #5 of 11 Old 09-01-2013, 07:30 AM
Macon's Avatar
It's my impression that oil temp is the most accurate you can get on these things, and it's the only one of real concern on the engine anyway. At cruise, in 95-100* days, I see around 185* oil temp. If you're below 200*, I wouldn't be too concerned. Are you sure you're hearing the fan and not the AC compressor?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #6 of 11 Old 09-01-2013, 08:09 AM Thread Starter
alaskan155's Avatar
Quoted: 65 Post(s)
yes its the fan i know the difference between the a/c compressor and fan clutch when its locked vs free spinning, those are are 2 very different sounds, Ive replaced about 2 or 3 now due to said reasons above, but never replaced one because it engaged to much lol.
was more curious weather it was normal or not?
(same sound btw when i am in the big truck and the fan kick on or i switch the fan on with the switch on the dash)
I am going to run my torque app next week and see what my trans temp and oil temp is on the drive home and see if it is engaging at the same temperature(give or take),
sounds like mine is just getting wore out at almost 128k miles because sounds like most of yours are quiet/free spinning most of the time lol
post #7 of 11 Old 09-01-2013, 08:18 AM
Macon's Avatar
With the varying levels of experience around here, I had to ask. Mine is pretty quiet. I hear it engaging on long climbs and at low speeds, but not as a normal course of behavior.
2002 F250 CCSB 4x4
Macon is offline
post #8 of 11 Old 09-02-2013, 06:11 AM Thread Starter
alaskan155's Avatar
Quoted: 65 Post(s)
its all good and yeah that part of the reason i think it might be going out, but we will see
post #9 of 11 Old 09-04-2013, 03:57 PM Thread Starter
alaskan155's Avatar
Quoted: 65 Post(s)
morning
ning
evening
not to sure if temp are in line and since there is no coolant temp sensor, looks like it might be kicking the fans on for my trans, hotest temp the engine oil got was 217 and trans was 187
are those good or bad temps? has high and low on the guage
looks like the trans is in check with this chart online
post #10 of 11 Old 09-04-2013, 04:10 PM
Macon's Avatar
EOT and TFT both look high to me on your afternoon image. I've seen over 200* EOT once, and that was a hot day that found me romping a lot. I don't recall for sure, but I think my TFT only hit about 180-190* that same day. Something is making your truck run hot. Since your EOT is up there, your TFT will be as well (being cooled with the coolant and all).
If you're chipped, go back to stock and see what that does for you. It could also be a clogged radiator, bad thermostat... Things that can make a truck run hot.
2002 F250 CCSB 4x4
Macon is offline
