Oil test results - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-28-2013, 03:38 PM Thread Starter
Oil test results
http://www.americanscrapmetal.com/im...350-082613.pdf
My oil test results came in what you guys think?
ascrap2003 is offline
post #2 of 5 Old 08-28-2013, 04:34 PM Thread Starter
2002 7.3 235K miles
DAVID:
Universal averages are based on ~5,600 miles of oil use, and your wear metals are still generally lower than average,
showing no obvious signs of mechanical problems. The only highlight was sodium -- that's not usually an additive in
diesel-use oils, so it might show a trace of coolant. Not enough to be sure, though; as long as you're not losing
coolant, go another 2,000 miles on this oil and check back to monitor.
ALUMINUM 4
CHROMIUM 1
IRON 14
COPPER 3
LEAD 2
TIN 1
MOLYBDENUM 87
NICKEL 1
POTASSIUM 1
BORON 379
SILICON 8
SODIUM 40
CALCIUM 1731
MAGNESIUM 429
PHOSPHORUS 1198
ZINC 1482
post #3 of 5 Old 08-28-2013, 04:48 PM
alaskan155's Avatar
Quoted: 66 Post(s)
if your loosing coolant your oil cooler might be leaking into the oil other than that it sounds like results are good/average
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #4 of 5 Old 08-28-2013, 05:15 PM Thread Starter
Oil Test
So
Inj Buzz & CCT If thats ok than
New Fuel Pump & Hutch/Harpoon
New Sticks & O rings
Maybe New Rocker Ball Bearings &/Or Pushrods "Top End Tune Up LOL"
UVC Harnesses
Glow Plugs & Relay
Oil cooler rebuild
Riff Raff Fuel X over
New ICP & ICP Pigtail
International CPS
6637 Or Whatever Filter
Some questions yes again
Can I just use a inline filter before/after the hutch/harpoon between the tank & pump? Something such as: Fleetguard Inline Fuel Filter FF5006
Or does it need to be the water seperater type?
My truck is for pulling & aint planning on having a egt gauge soon so
Should I leave it stock or:
Stage 1 sticks w/ tow tune
Stock sticks w/ tow tune
Already has a DP looks like to me, but ebpv is still on.
Just want some extra grunt but only if longevity aint a issue including hurting the hpop or o rings.
post #5 of 5 Old 08-28-2013, 10:05 PM
timmyboy76's Avatar
timmyboy76 is offline
