7.3l no start after rebuild - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-28-2013, 08:39 AM Thread Starter
1st time here- I did a complete rebuild of my 01 7.3 PSD after melting thru a piston. Put remanufactured heads on it, and used a Ford OEM rebuild kit with .020 pistons. Now it will not start. #1 injector is leaking oil out of the top, and I assume that will not allow the HPOP to generate enough pressure to drive the injectors. I replaced the O-rings for a second time on that injector, and even replaced the head b/c it looked like the machined surface was rough and might not seal.
Still leaking, is it possible the injector itself has cracked??
Also- when I am cranking it over, the oil pressure gauge does not move, and I have to keep refilling the HPOP reservoir. Is that normal?
ffcrapp is offline
post #2 of 7 Old 08-28-2013, 09:22 AM
ADMIN AND TECH
SCUFFY828's Avatar
as far as the injector leak , probably the injector itself is bad ,internals are worn , did you prime the base pump when installed on front of engine , sounds like you aren't getting prime , it does take quite awhile for all the oil to build back up after the engine has been apart and everything is dry , which im sure you know , if you have to keep filling reservoir then its not pulling oil from pan
ITS STOCK
SCUFFY828 is offline
post #3 of 7 Old 08-28-2013, 09:34 AM Thread Starter
Priming the LPOP
So, I did not prime the pump, didn't know it needed it. Will it catch eventually, or do I need to pull it off and prime it? If so, what is the procedure?
ffcrapp is offline
post #4 of 7 Old 08-28-2013, 09:40 AM
timmyboy76's Avatar
somethings' not right, with hpop draining back. Did you install the correct hpop gasket? Check the C.V. below the hpop / drivers side for debris..etc? Inspectthe standpipe from pan to hpop for crack/s? Use new injector orings? Lay a straight-edge across injectors for proper "seating"?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 7 Old 08-28-2013, 10:08 AM Thread Starter
I don't think the HPOP is draining back, it is just not getting filled automatically as I crank the engine trying to get it to start. I put new O-rings on the injectors when I did the rebuild (OEM ford O-rings), and none of the other injectors seem to have a problem. Can't see any cracks or damages to the injector in question, and it wasn't dropped, pried on or mishandled during the process...
ffcrapp is offline
post #6 of 7 Old 08-29-2013, 04:50 AM
ADMIN AND TECH
SCUFFY828's Avatar
they can catch eventually but still doesn't need to really be spun over without some kind of lubricant , as far as procedure , just pack the gears with some assembly lube , Vaseline , wheel bearing grease , anything that will help it just catch prime ,and see if that makes any difference
ITS STOCK
post #7 of 7 Old 08-29-2013, 03:56 PM Thread Starter
As far as laking injector, can you put a fatter O-ring in the top groove to fix? Any chance the injector itself can crack?
ffcrapp is offline
Tags
hpop , injector , oil leak
