7.3 Miss and no power - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-25-2013, 09:34 AM Thread Starter
Hi all,
New to this forum and I am looking for some help here. I have a 2000 F350SD with diy air intake, DP Tuner stock, 20hp, and 60hp tow, BTS auto trans, everything else is stock. I have approx. 150K miles and I am having this intermittent miss happening while driving and the Service Engine Soon light comes on. When I pull over and shut the truck down and restart it all is fine again for a while and sometimes just putting it in neutral will make the light go out and the truck will idle and run fine. I have read several posts concerning the injectors, the uvch, anda few other possible causes. I have put a code scanner on it and no codes are pulled, have checked the turbo blades, turbo air intakes, uvch connectors on the outside of the valve covers and I will be doing a fuel pressure test this week. Is there anything else I should look at before taking the valve covers off to inspect the wiring harneses on the inside. Thanks in advance for all your help
Don276 is offline
post #2 of 5 Old 08-25-2013, 10:02 AM
sldghamr's Avatar
have you looked into the injector driver module?
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #3 of 5 Old 08-25-2013, 11:07 AM Thread Starter
I have considered it but I am not sure how to test it with out running a buzz test
Don276 is offline
post #4 of 5 Old 08-26-2013, 04:00 PM Thread Starter
Update:
I just found the ICM Sensor wet with oil, and considering this to be a possible culprit. Will be replaceing in next few days. Whats everyones opinion on this being the possible cause
Don276 is offline
post #5 of 5 Old 09-03-2013, 01:35 PM
Quoted: 728 Post(s)
It could be ICP, especially with oil on it.
Corey@CNCFAB is offline
