Turbo Surge question
Im not too sure if this question belongs in this forum, but i'll ask it anyways. When accelerating hard, I notice that my boost needle bounces around as my boost numbers raise. The needle however doesnt bounce around at low boost numbers. Am I experiencing "turbo surge" or is that something else?
What is your definition of "turbo surge" anyways??
Do you have your boost fitting in the aih or do you have it t'd into the map line?
After reading previous posts concerning this topic you should probably be feeling turbo surge and if not at least hearing it. It'll sound almost like air is being compressed and released repeatedly. Typically this will show the worst under 2000 rpm at WOT while towing but this isn't definate. Last edited by Marty; 10-19-2006 at 03:10 PM. |
03F350 - - Turbo Surge will destroy your turbo! Not sure about the efficency of that setup. What kind of turbo are you getting? If it is a garret bb or turbonectics you plan on upgrading to, you may want to PM csipsd about it.
Yes I know that is why im planing on getting a diffrent turbo very very soon im looking for the most effiecent tubro but also cost effective...
Alot of times I will get the surge when pulling a hill in 5th( or 6th, whatever you want to call it.) Thats when I see it the most.
ok im confused i dont know if the sound im hearing is turbo surge, compressor surge, turbo stall, or just the normal wastegate blow off, this video link is a video of the sound instead of trying to explain it ill let you listen for yourself you need to turn it up to beable to tell between engine noise and the turbo noise the description next to the video explains whats goin on. plz help im not wanting to drop 1500 on a new turbo..
http://www.youtube.com/watch?v=y6JXQg1gTQM |
