Idles but wont rev past 1200 rpm - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-22-2013, 05:46 PM Thread Starter
Pulling camper engine stalls restart and step on pedle engine dies after letting it idle and veey gently i take off no more problems till i shut it off and start again. Got it home, new fuel filter no help. New cps no help so i looked at fuel filter again and figured out it was pumping air into filter so done hutch mod now got clear fuel. Truck will start and idle fine but step on the peddel and at 1500 rpm it shuts off. It will restart and idle but no accelerate. Put original cps and same thing. Could it still be the cps or do i look somewhere else.
th0m is offline
post #2 of 7 Old 08-24-2013, 06:29 PM Thread Starter
Anybody know of a powerstroke fourm where i can post a question about a problem with my truck. I really need help.
th0m is offline
post #3 of 7 Old 08-24-2013, 07:20 PM
shiz big red's Avatar
Is it chipped? Which cps did you get?
shiz big red is offline
post #4 of 7 Old 08-24-2013, 07:30 PM
miked.'s Avatar
is the camper still hooked to it? once on a 95 psd my electric brake controller went bad and every time i touched the brakes it would kill the engine. could possibly be valve cover harnesses. check the nut on the ipr behind the hpop.
miked. is offline
post #5 of 7 Old 08-24-2013, 08:10 PM Thread Starter
Not chiped, its auto store cps thats why im thinking it could be bad but it and the original one give same results whice dont seem likely. Ill check the ipr nut in morning. Wouldn't a wireing harness problem be isoltated to some cylinders not all.
Thanks for youre replys. Th0m
th0m is offline
post #6 of 7 Old 08-24-2013, 08:32 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Is there any codes is pull them even though there no cel
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #7 of 7 Old 08-24-2013, 08:43 PM Thread Starter
I dont have a code reader but i might have to find one
th0m is offline
