PCM Problems? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-22-2013, 08:38 AM Thread Starter
PCM Problems?
Hi
I have a 02 PSD with what I suspect is a problem with the PMC.
It all started when I removed the terminals on the batterys. When i reconected the batterys the Edge Evolution that was on the vehicle started to reprogram itself. But it just stated to go in loops. By that i mean that it just reprogram an reprograme itself. So I contacted Edge an they updated the unit. When i then pluged in the Edge unit it just did the same thing over again. I then called back to Edge and they ment that by removing the terminals on the batteys it some how deleted my PCM. So now when I try to crank my car it only tics and all the warning ligths an gauges blink an go crazy and the engine does not turn over.
Do anybody have any input on what this can be.
Thanks
Morten
From Norway, but have to say! The US is a better country.
The_Lone_Walker is offline
post #2 of 3 Old 08-22-2013, 09:13 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
Here's a Long-Shot but, with those symptoms, the fact it's an '02, AND that you messed with the battery cables right before it happened ,,,, have a look at this connector.
POTENTIAL ELECTRICAL CORROSION if your truck is like mine......
NoRalPh is offline
post #3 of 3 Old 08-22-2013, 10:02 AM Thread Starter
Thanks I'm going to check it tomorow. hopefully it is just that.
