2000 7.3 cranks will not start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-20-2013, 01:41 PM Thread Starter
History: Towing rv truck shut off would not restart. Had towed to mechanic, ran snap on scanner buzz check good, then would not connect. Diagnosed as bad PCM. Replaced pcm, then failed buzz check, replaced IDM.
Towed it home. Replaced valve cover gaskets and harnesses, did point to point ohm checks all injectors check ok @ 2.5 ohms, glow plugs all fail, replaced glow plugs. GPR replaced, opened wiring harness checked all wires no breaks, correct voltages/ohms at all sensors and IPR. Removed and cleaned IPR new orings. put pressure gauges in fuel bowl, 90 PSI when key on, in left head in place of pressure sensor, 1000 psi while cranking at 200 RPM, put in new ICP. Replaced CPS.volts at 10.8 when cranking.
Truck tries to start but will not catch and take off sounds like running on 3 cyl.
Where do I go from here?
Msmith9c is offline
post #2 of 4 Old 08-20-2013, 01:51 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Heres a flow chart that a very smart member on here gave me awhile back
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 4 Old 08-20-2013, 01:56 PM
Chapter Director
Quoted: 5 Post(s)
Its for OBS 7.3s but they are about 95% the same so it will help pinpoint your problem
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 4 Old 08-23-2013, 12:12 PM Thread Starter
The problem was the check valve in the fuel bowl was stuck shut. Runs great but still for sale
Msmith9c is offline
