deccelaration tapping, knocking - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-19-2013, 09:04 AM Thread Starter
My truck makes a light tapping, knocking sound when I let off the gas. I have had 2 1 5spd & a auto & both do it. This normal valetrain noise? You can only hear it if listening closely with ac & radio off.
ascrap2003 is offline
post #2 of 4 Old 08-19-2013, 11:01 AM
Can you describe the noise in more detail?
If its what I think you're describing, it's normal...but I could be thinking of a totally different sound
2001 F-250 XLT
6637 air filter, zoodad w/ custom enclosure, 4" TB straight pipe w/ 5" tip, water injection, PHP hydra-chip, boost, EGT & trans temp gauges, Sonnax valve tricumulator kit, AIH delete, foil delete, external IC/TC water mist spray
Troponin is offline
post #3 of 4 Old 08-19-2013, 11:47 AM Thread Starter
Best way I can explain it is a sound up on top, I had another truck that made the same sound 20k miles later it didnt get louder. Just want to make sure it aint a rod/wrist pin or bearing. Do those start of slow or all of a sudden & bang? I have a video of the sound on another post in this section under: Knock!
post #4 of 4 Old 08-19-2013, 11:48 AM Thread Starter
Here's the link:
Knock?
