I ran my 01 diesel excursion out of diesel...... now not running - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-18-2013, 06:10 PM Thread Starter
I was heading down the road and the fuel light came on then about 5 min. later it was spitting and spudering, so I pulled off the road. It never acually died, but was running really rough. I put 5 gallons of diesel in it. Now it will start, but runs really rough and will not rev up at all. I cracked the fuel bowl drain under the fuel filter housing and trided to prime it a little. Alot of diesel was in the fuel bowl. I dont know what else to try. I got a tow back to my house but I need my truck for work Monday morning. I saw something about putting air pressure in the tank?? Any help welcomed as this truck is new to me. Thanks in advance
rehahomes is offline
post #2 of 7 Old 08-18-2013, 07:00 PM
just let it idle. every 15 or so minutes go out and try to drive it until it clears up. if you cracked the fuel bowl and it had diesel in it then you just have to let it work the air out of the system
Moto2four is offline
post #3 of 7 Old 08-18-2013, 08:43 PM Thread Starter
Even it runs very rough like....450 rpms?? I'm scared I'm going to hurt something.
post #4 of 7 Old 08-18-2013, 09:03 PM
CSIPSD's Avatar
Fill up the tank... More then likely you may have sucked a bunch of crap into the mixing screens and they could be plugged. But before going that far I would get at least 15 gallons in the tank.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 7 Old 08-18-2013, 09:26 PM Thread Starter
Okay I'll put a hundred in the morning. It is already gettting better and better. Thanks for the advice. I'll keep you all updated.
post #6 of 7 Old 08-18-2013, 09:34 PM
Quoted: 725 Post(s)
What moto said. These trucks are not like your typical old school P-pumped type diesels where you have to crack the injectors and prime them.
Corey@CNCFAB is offline
post #7 of 7 Old 08-19-2013, 08:04 AM Thread Starter
Its almost cleared up now, or it is heading in the right direction. Thanks again for all the speedy replies!
