Low Boost? - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 17 Old 05-16-2008, 10:33 PM Thread Starter
lords88's Avatar
This sucks! First of all I ended up as the DD tonight for some friends then after I drop them all off I drive home and find out that my boost has dropped from a whopping 20 to 17. WTF! Then as I pull into my parking spot I notice a little puddle so I crawl under the truck to find I have a small coolant leak and THEN on top of that one of my summer tires which I put on my truck yesterday is going flat and has a HUGE hole in it! Holy crap if it isnt one thing its three! Okay so to getting this solved. How do I use a boost leak detecter "pvc pipe with are hose connection"? Do I just clamp it in the intake hose and then turn on the pressure and then listen for leaks?
Yes, the Lord drives a
2002 F250 super cab w/long bed
, Built 4r100 trans, rapid flow intake, zoodad mod, wicked wheel 2, foil delete, bellowed up pipes, Custom Wildman Tunes!
, 4'' exhaust, 5'' rolled chrome tip, dual trans coolers, cooling mist inject, wheels, tires, tinted windows, and all the chrome accessories I can stack on it!
Ty Lord
lords88 is offline
post #12 of 17 Old 05-17-2008, 09:01 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Here check this out will give you an idea of what you need.http://www.dieselsite.com/index.asp?...ROD&ProdID=607
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #13 of 17 Old 05-17-2008, 07:13 PM Thread Starter
lords88's Avatar
Well I made my own set up checked it out and i have a serious leak coming from the up pipe on the drivers side. What all do I need to do to fix that. That is the donut gasket leaking, correct?
Ty Lord
lords88 is offline
post #14 of 17 Old 05-18-2008, 02:17 PM Thread Starter
lords88's Avatar
Bump, bump, bump, bump
Ty Lord
lords88 is offline
post #15 of 17 Old 05-22-2009, 06:42 AM
Drepka's Avatar
Send a message via Yahoo to Drepka
BUMP BUMP BUMP
Traded in the 00'
TW 6 pos. chip......reinstalled
Isspro gauges.....Finally in 04-27-09
DIY Tymar.....04-21-09
Zoodad.........04-22-09
Foil delete.....04-22-09
next:
Leveling kit--delayed-wife totalled new car!!!!!!!!!!
4" turbo back MBRP....installed !
305/70/16 Goodyear Wrangler Silent Armors-- done yesterday
Drepka is offline
post #16 of 17 Old 05-22-2009, 09:13 AM
Living on a prayer
i was going to suggest checking the boost sensor fitting and the gauge line, but sounds like you found the problem in the up-pipe. do a search for "donut" and you should find some info here. i guess bad donut gaskets are a common enough issue, but i've read about up pipes rusting out.
Early 99 (7/98) F-350 CC 4X4 AT 7.3L 200K mi - 4" turbo back w/muffler - AFE Stage 2 - PMT1 ECM - DP 40T/DECEL/80E - dual trans coolers - HPX - Fuel CCK - Auto Meter Trans/EGT/Boost - 3.73 - stock tires
samiam is offline
post #17 of 17 Old 05-22-2009, 09:18 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Get you some exhaust donuts for a small block cheby and use those, you will also prolly need a new up pipe as its prolly eroded.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
