No power seized turbo - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-15-2013, 07:20 AM Thread Starter
orangestroker99's Avatar
First off just wanted to say hey everybody im new to the forums I have an early 99 that doesnt have any power. I had a scanner put on the truck and it threw an idm fault code. Got back home from the test drive with the scanner plugged in and the turbo was seized. I have no idea what would cause this the truck has 140k miles and there wasnt any signs of play in the turbo at all and then all of a sudden it just froze up. Took the old turbo out and im replacing it with a d66 and blank pedestal. But im afraid that if theres an oiling issue that it would freeze the d66 up too. Also a side note my icp is covered in oil but it hasnt failed yet. The cycles were fine
orangestroker99 is offline
post #2 of 11 Old 08-15-2013, 07:22 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
did one of the oil lines plug? Oil line to the turbo!
2000-7.3L is offline
post #3 of 11 Old 08-15-2013, 07:34 AM Thread Starter
I dont know but how would i check if one of the oil lines is plugged?
post #4 of 11 Old 08-15-2013, 07:35 AM Thread Starter
And correct me if im wrong but i thought that the oil just comes up from the block and through the pedestal to the turbo?
post #5 of 11 Old 08-15-2013, 07:39 AM
timmyboy76's Avatar
ya, thats correct. your going to want to change the ICP too.
With the turbo freezing up, inspect the "condition" of the compressor wheel. Any "chunks" missing from the blases, you'll want to inspect further down the air travel for the missing pieces...ie IC.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 11 Old 08-15-2013, 07:47 AM Thread Starter
Ya i figured i would change the icp after i get the turbo on this weekend. And also the compressor wheel is completely fine. No chunks missing that i noticed. How would i check for missing pieces?
Early 99, eclb, d66 turbo, jasper stage 2 trans, homemade intake, 4 inch dp to 5 inch straight pipe, edge tuner soon to be ts chip, triple pillar w/ isspro boost pyro trans, 4" lift, 325/60 terra grapplers on 18" mazzi hulks, helper rear air bags
post #7 of 11 Old 08-15-2013, 08:00 AM Thread Starter
Also I think the reason it froze was because i was being an idiot and ran it hard then shut it off right away quite a few times
post #8 of 11 Old 08-15-2013, 08:18 AM
timmyboy76's Avatar
can you move/spin the compressor wheel? Weird how theres no "damage" to it.
post #9 of 11 Old 08-15-2013, 08:23 AM Thread Starter
No the thing wont move at all. I think it may have gotten really hot and then i shut it off and that caused it to freeze or something
post #10 of 11 Old 08-16-2013, 06:42 PM Thread Starter
I got the turbo on today and its all good and working good but the truck still has no power at all. its making good boost. i know that the icp sensor is failing but dont think it wouldve caused these symptoms. im thinking the uvch
