starting problems w/ 2000 f350, please help! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-11-2013, 10:55 AM Thread Starter
I have a 2000 7.3l f350, i have been having starting problems for a couple weeks(takes awhile longer cranking before turning over). It has now gotten to where it wont crank, just a single click when i turn the key. i have tested the batteries and they are good, we had the starter replaced last year. I have tried jumping the starter solenoid and all i get is repeated clicks. What could be wrong? I have heard tapping the starter with a hammer sometimes works, is that a good thing to do?
fordgirl821 is offline
post #2 of 6 Old 08-11-2013, 12:07 PM
redogg322's Avatar
Send a message via AIM to redogg322
You need to see if the power is making down to the starter . It could have a loose cable somewhere. Also check the connections at the batteries if they are corroded it won't crank.
00 f-350 4 door long bed 4X4
Nitto Terra Grapplers
7.3 4" downpipe with 5 " Exhaust Stacks
[EMAIL="
redogg322 is offline
post #3 of 6 Old 08-11-2013, 12:16 PM Thread Starter
i checked it and there is power at the starter, should i tap the starter with a hammer?
post #4 of 6 Old 08-11-2013, 12:29 PM Thread Starter
i tapped it and it started cranking, so ill get a new starter
post #5 of 6 Old 08-11-2013, 01:31 PM
redogg322's Avatar
Make sure it has a good clean and tight connection before dropping money
[EMAIL="
post #6 of 6 Old 08-11-2013, 04:38 PM
Quoted: 762 Post(s)
Where did you buy the starter? Autozone and parts stores as such usually don't last long. Same goes for water pumps, alternators, master cylinders, etc.
Corey@CNCFAB is offline
