truck will not start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-08-2013, 12:58 PM Thread Starter
bec
truck broke down on a route sitting idling just shut off.took a camshaft sensor out to the site still did not want to start .took scan tool looked at icp would not build pressure.had truck towed in.started blocking off cylinder heads left and right with no pressure build up. dead headed pump and still had no pressure.straight voltage to ipr still would not build swapped ipr still no pressure .pulled hpop and had a rough spot when turning replaced pump.still no pressure.resevoir stays full.ipr goes 65% when turning truck over.looked for regulator on oil cooler did not see one externally found a regulator when i pulled oil filter off seems to be fine. 395000 miles on truck.any help would be appreciated thanks brian
bec is offline
post #2 of 11 Old 08-08-2013, 01:17 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Try unplugging the pigtail on the icp and see if it starts, if so it means the icp is dead. When you unplug it the pcm give the ipr a default value and will allow it to start
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 11 Old 08-08-2013, 01:21 PM Thread Starter
bec
i have unplugged it and it did not make a difference.
bec is offline
post #4 of 11 Old 08-08-2013, 01:23 PM Thread Starter
bec
i did notice icp reads 39psi with engine off.disconnect it and it goes to 0
bec is offline
post #5 of 11 Old 08-08-2013, 01:27 PM
Chapter Director
Quoted: 5 Post(s)
Thats weird...your icp should be about 500 while cranking im leaning toward hpop, Check your hpop reservoir and if its less then 1/4 in from the top then i would say its your hpop
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 11 Old 08-08-2013, 01:28 PM Thread Starter
bec
did notice on the last crank oil light flickering did not have a gauge pulled out oil pressure sensor on top of resevoir and no pressure or oil even trying to come out.notice it says 10psi at curb idle.pulled one of the hpop lines from the cyl head put in a jug turn it over and no oil coming out.how is this oil system circulate.resevoir is full of fresh oil with all the turning over i did i would have figured i would be seeing the norm dark engine oil mixing.thanks
bec is offline
post #7 of 11 Old 08-08-2013, 01:29 PM Thread Starter
bec
replaced hpop today with same results.
bec is offline
post #8 of 11 Old 08-09-2013, 02:56 PM Thread Starter
bec
Ok pulled crankshaft pulley to find lpop wore out.found engine cover to have about 4 to 5 thousandths groove top and bottom where pump runs.any success j b welding to fill in grooves?395000 miles on engine
bec is offline
post #9 of 11 Old 08-12-2013, 12:25 PM Thread Starter
bec
thanks rammstein for the repliesgot the truck fixed.guess you got to be in the click on this forum 111 +VIEWS
bec is offline
post #10 of 11 Old 08-12-2013, 12:30 PM
Chapter Director
Quoted: 5 Post(s)
No problem i just was dealing with my own no start ordeal(ended up being loose connector on PCM) but you will get there. A journey of 1000 posts begins with a single post or something like that
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
