anti drain back valve location - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-07-2013, 04:38 PM Thread Starter
I'm trying to go through and narrow down why truck is having starting issues after sitting for long periods (8-10 hours) the reservoir drains down and was going to check the anti drain valve (or whatever its called). Is it below and to the right of the reservoir on top of the block and has a 3/8" square hole that you put the extension in? If I'm looking at the right plug then that s.o.b. is in there and I put a good deal of pressure on it to get it to break loose before I told myself that maybe I'm cranking on the wrong thing and probably should ask you guys, if I am in the right spot then tomorrow I'll strap on my big boy boots to get her broke loose
2003 f250, 290k +, ts 6 position, hutch mod, harpoon mod, stancor, 4" mbrp
rogerm311 is offline
post #2 of 2 Old 08-08-2013, 10:32 AM Thread Starter
Nevermind got it unstuck, looked fine and put back, now on to checking something else. Still not sure why its draining down
