Flickering Battery Light - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-06-2013, 06:20 AM Thread Starter
Is there a chronic problem with the positive batt cable (dual harness) clamp on the pass-side battery in these trucks breaking down, or softening? I've seen several (including mine when I bought it) with a screw lodged between the post and clamp to secure the connection. I removed it, tightened the clamp as best as I could. The lead is soft. Then I replaced both batteries, and the plug on top of alternator, and even put an adapter on the clamp, but batt light still flickers. Thinking I'll finally have to buy new positive cable harness for that battery. Does anyone here have experience where this fixed the flickering light? Thanks!!
2001 F350 Lariat 7.3L 4x4 CC SB
BFG-AT 35x12.50R16.5, 4" Lift 173,000mi...so far
RafterQ is offline
post #2 of 4 Old 08-06-2013, 11:42 AM
I am curious on this too...have similar problem.
wizkidzulu is offline
post #3 of 4 Old 08-13-2013, 05:11 PM Thread Starter
Bump......
RafterQ is offline
post #4 of 4 Old 08-13-2013, 05:12 PM Thread Starter
Plus, I may have a parasitic battery drain going on
RafterQ is offline
