miss after glow plug install - Ford Powerstroke Diesel Forum
Old 10-14-2006, 07:34 PM
so I put some new plugs in my truck and now it has a miss. I put new plugs, wires and gasket all Ford OEM. I have rechecked all my conections and nothing. It started up some smoke and the check engine light came on. I dont have a code reader to know what it is saying. Also how can you get the light to go off?
Thanks
Old 10-14-2006, 07:38 PM
unless its a california truck.....glow plugs wont cause a check engine light...meaning the code is crutial to figuring out the wiring problem that probably is the cause for your concern..
Old 10-14-2006, 07:50 PM
Ya I have been on the verge of getting the sct from DP Tuner or the edge evo. Do you thing the oil that went in the cylender could have messed up the injecter?
Old 10-14-2006, 08:09 PM
No, its either unrelated to the repair or its an electrical problem. You cannot put enough oil into a cylender by just replacing a glow plug to cause a problem
Old 10-18-2006, 01:39 PM
Got my codes need more help
SO I pulled my codes with my edge evo and got P0603 and a p1316. From what I have read the P0603 is common with a chip. The p1316 is what worrys me. I have tripple checked my valve cover and wiring with an omm metter and tryed and old one I had laying around and no help. Is it time to take it to a shop? What can I do?
Thanks
Old 10-18-2006, 02:06 PM
just cleared the code no I just get the p1316
