Help! Shutdowns & Sputters - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-31-2013, 04:46 AM Thread Starter
I would appreciate some help if anyone has any ideas.
I have a 2002 E450 7.3 14í Utilimaster box truck. Truck has 62k original miles. Iím experiencing intermittent stalling, hesitation and shut offs, predominantly in the lower RPM range. Power level seems a little off too but hard to tell. The truck starts fine, idles fine and appears to run ok at higher RMPs. I donít have a tach so I have no definitive RPM numbers to offer. When I step on the accelerator pedal the truck will buck, stammer, stutter, sometimes stall completely or eventually take off when the RPMs climb. Under load in higher RPMs the engine appears to run pretty steady. When it does stall out it generally can be restarted immediately.
I have replaced the cam position sensor with a new spare I keep in the truck and purged the fuel bowl a couple times to no avail. I guess itís possible but not very likely my replacement cam position sensor is bad. I have another replacement I could try. Engine oil is newer 10 -40 Rotella filled to proper level, air filters are new, fuel appears ok as I always get it from the same station with above ground tank. Fuel filter is maybe 2 years old with 3k miles on it. I will pick up a new one today as a precaution. No codes are present and no warning lights appear. No oil or fuel leaks are visible.
Based on what Iíve read the most common issues with these symptoms include:
ICP
IPR
UVCH
I have a buddy coming over with a professional mechanics scanner as mine is a simple ODB2 which doesnít allow for diagnostics. Thoughts on tests to run? Places to start? Really need to get this thing fixed and get back to work.
All suggestions appreciated.
stoutlogic is offline
post #2 of 3 Old 08-01-2013, 03:07 PM Thread Starter
In case it helps anyone else I believe I found the problem. I used a buddies Snap On scanner to run a few tests and pulled a P1298 code (injector driver Module). It was the only code registered.
I went ahead and removed the IDM. As I pulled it from the vehicle I could hear a sloshing sound. Upon breaking the seal and removing the cover there was about a cup and a half of foul water within.
I haven't found a replacement yet, might try and clean this one out and reinstall.
-Cheers
post #3 of 3 Old 08-01-2013, 09:55 PM
timmyboy76's Avatar
did you mean, 15/40 rotella or the 10/40 you mentioned?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
