runs fine cold 5 miles starts missing - Ford Powerstroke Diesel Forum
post #1 of 19 Old 07-28-2013, 03:03 PM Thread Starter
2001 187k 4in turbo back, super tuner, cold air intake, started all of a sudden . it runs great 1st start of the day for about 5 miles the starts to miss it gets progressively worse til it stalls. regular oil changes, seldom run tank low, has 1/2 now . I did a search not sure where to start hutch mod, IPR, its not setting the ses light but code p0603 comes up any help is appreciated
slam is offline
post #2 of 19 Old 07-28-2013, 03:08 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Once you let it cool off, does it start up and run fine until warm again?
If so, sounds like your high pressure oil system has a leak somewhere not allowing enough HPO to get to the injectors.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 19 Old 07-29-2013, 06:20 AM Thread Starter
yes, let it sit over night went out started fine ran about 5 miles started missing , put it in driveway tried to keep running within a minute or two stalled
slam is offline
post #4 of 19 Old 07-29-2013, 06:30 AM Thread Starter
In the time it took to post it restarted and ran good for a couple of minutes then stalled , I immediately opened fuel drain and fuel sprayed out of bowl. don't think its a fuel issue. don't see any major oil leaks around hpop. is this something that fails?
slam is offline
post #5 of 19 Old 07-29-2013, 07:41 AM
c69ss396's Avatar
I'd try a CPS first.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 19 Old 07-29-2013, 08:01 AM
jesilvas's Avatar
Quoted: 2 Post(s)
With high pressure oil, you'd usually see it.
I'd check for oil in your coolant bottle and your fuel bowl to see if high pressure oil is leaking to those systems for some reason.
If not, then you're gonna need to monitor live data from the ICP and IPR to see if either is messing up, because otherwise it's a guessing game.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 19 Old 07-31-2013, 11:13 AM Thread Starter
Replaced the cps no change any other advice. I am in ft myers fl
slam is offline
post #8 of 19 Old 07-31-2013, 02:46 PM
timmyboy76's Avatar
whats a "super tuner". Can that be umplugged? If so, try it.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #9 of 19 Old 07-31-2013, 04:39 PM Thread Starter
My bad its the super chip programmer. i have returned to stock and put back in performance mode no change. I might have a local guy with a diag tool to check , if it would run more than 5 mins i would take it some where I hate having anything towed
slam is offline
post #10 of 19 Old 08-01-2013, 01:54 PM Thread Starter
I replaced the ipc sensor on the advice of the local guy, 175 bucks no change. is there a scan tool that is affordable to help diagnose this thing?
slam is offline
